FixYa.com
Tags:
Microsoft Windows Vista Ultimate Edition
Not working
posted by kavs89 on Jul 26, 2008
MS-DOS applications are not working in windows vista.how do i make them run like in windows XP.
Comment by kavs89, posted on Jul 27, 2008
even after creating a shortcut for cmd and putting everything in double quotes the program fails to start.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 04, 2008
Not Rated (0)
JulesPCaut
Rank:Apprentice Apprentice
Rating: 40%, 1 votes
Just start the CMD.EXE from the Run option in your Start menu.
Then type your MS-DOS program name. Possibly it will show you an error that can help solve the problem.
If you double-click the MS-DOS program or start it together with the CMD.EXE, the Command window will close immediately after the program fails to start. So you can't see any error if there is any.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 26, 2008
Not Rated (0)
debor19071
Rank:Wiz Wiz
Rating: 82%, 15 votes
Do a file search for cmd.exe and then you can create a shortcut on your desktop pointing to it and then in double quotes put the location of the application you are trying to execute, ie.. It should be located on c:\windows\system32 - cmd.exe
C:\WINDOWS\system32\cmd.exe - in Properties Target and put this in double quotes and then your application with the full path in double quotes after that.
Can you Help with these Operating Systems problems?
downlode theams
I want to downlode some theams Answer This...
trasformer mon P4
je veut tranformer mon P4en... Answer This...
can't play pc game barbie
can't play pc game barbie as... Answer This...
window vista dvd drive
my dvd drive does not read any... Answer This...
Ubuntu
is there a driver I can... Answer This...
Repair Service
Find Operating System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
