Question about RCA HD50LPW42 50" Rear Projection HDTV
Picture is very dark will not brighten
I have an RCA hd50lpw62a, the picture is very dark. Making adjustments to the picture do not help. Someone told me the lamp could be weak, others have told me that the lamp is either good or bad no inbetween. Hate to by a lamp just to see if that is the problem.
  • 1 more comment
  • Maibe Dorite Aug 12, 2008
    Yes, this April,2005 RCA model #HD50LPW62A was a floor model at Wal-Mart and the picture has been dark for a few years(couldn't adjust dark picture) then yesterday turned it on and heard a loud pop and then a weird noise with sound but no picture so we took the back off and noise sounds like it is coming from lamp area when we take the lamp out we don't get the noise and the lamp looks good no indications it's blown so what else could it be? Checking the lamp for continuity indicates it's open.
  • sanramonbay Oct 19, 2008
    I have the same problem, changed the light and picture is still dark. Have you found a solution or at least have a diagnosis?
  • rockincranch Dec 08, 2008
    The lamp finally burned completely out I replaced it and the picture is fine now
  • 28 Answers
We changed the lamp too.Picture is very good now. There isn't a way to test lamp because it is filled with gas.when changing lamp make sure you put everything back on covers etc. before checking to see if it works.
Posted on Dec 09, 2008
Panasonic TH32LRU5 picture is too dark how do you brighten?
Access the TV's on-screen menu, tab through until you find the option to increase the brightness/contrast, and adjust it.
Nov 12, 2014 | Televison & Video
Turns on dark and then gets lighter
ic circuit is the problem, see TV Tech.
Nov 09, 2013 | RCA F32650 32" TV
Dark picture,can't get it to brighten up with menu color settings.
Assuming brightness and contrast (picture on some sets) does not help it could be a number of things, how old is this set?
Dec 15, 2012 | Sanyo DS25390 TV
I have an old Orion TV134R . The picture is so dark on it that I need night-vision goggles to watch it . How can I brighten it up? I don't have the original remote control. Thank you.
how about in the menu button you can not get an adjustment in brightness control. if the display in the screen is too dark either in any channel or even watching a movie from an input source like dvd player, then i may say that the picture tube need now replacement.
Aug 12, 2012 | Televison & Video
Blue Screen
no those tvs came with a black otuer screen that have rough ridges . If your screen is blue, someone may have replaced it with a dark colored plastic. You can get replacement screens at the following link, They are exspensive though.
http://servicemanuals.vstore.ca/
Jul 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Picture is dark
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
Feb 14, 2008 | Zenith C27A24T 27" TV
Bad picture
My had the same problem except mine has turned yellow tint. I paid 65 dollars for someone to come and look at it and they told me that is was the Blue tube went out. They qouted me 700.00 to fix it.
Nov 27, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
Dark and red picture
First you can up the screen voltage, by finding the HV transformer. It has Screen and Focus control on it this it the Transformer that is in back of set and has an anode lead going to Picture tube. Come up on the screen control slowly and if the picture brightens with vertical lines then it's too high, The red problem is a small transistor that maybe located on the CRT board. It's probably shorted. There are about 3, each going to the different colors Red, Blue, Green.
Sep 13, 2007 | RCA F35317 35" TV
The picture is dark
Hi This could be one of three possibilities, one the High Voltage Screen Adjustment is off, Two the Picture Tube is Weak, or Three there is a problem with the Video Drive Amp/Amps, these are things that should be checked or adjusted by a qualified technician, especially the High Voltage Screen Adjustment, hope this helps.
Apr 15, 2007 | Zenith H36F46DT 36" TV
RCA HD50LPW42 50" Rear Projection HDTV Logo
257 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
