Question about Brother GX-6750 Typewriter
Wong letters & numbers
My typewriter is still printing incorret letters & number even after i completely shut it off. What else can I do? We hvae the same problem - it's like writing in some super-secret undecipherable code. Waiting to hear if Wayne420's purchase of new daisywheel kit fixed the problem.
    Sergeant:
    Champion:
  • 347 Answers
Hello Mmlarsen,
Try to remove the wheel and clean the typewriter.
It is probably just dirt causing this.
Good luck, and anythign else you need let me know,
Dahaka
Posted on Jul 26, 2008
    Brigadier General:
  • 3,614 Answers
Have you done change the settings?
and also what is the model of the unit
  • micromaster
    micromaster Jul 26, 2008
    clean and check the daisy wheel part, dirt can cause the abnormality movement on the wheel..
  • Brother Master
  • 19,396 Answers
Bbrothers says its my daisy wheel causing this problem.
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
I began using my typewriter this morning...and when I press a number or letter...it types the wrong number, letter, or symbol. For example, I press the letter "F" and it types a number...
Turn it off and on it should go thru it's dance and rehome the print wheel. f you are notin KBII , language mode or the print wheel damaged the homing pawl for the P/W is probably broken you need a tech.
DickyO
Jun 09, 2011 | Brother SX-4000 Typewriter
Is there a way to set typewriter to type numbers and uppercase?
There may be a caps key. You can get a manual @ brotherinternational.com, click on support.
DickyO
Apr 20, 2010 | Brother SX-4000 Typewriter
When typing wrong letters and numbers type
You might have a "proportional space" printwheel but the pitch selector is on 10, 12, or 15 instead of PS. OR it is on PS but you have a normal print wheel. Try selecting different pitches. Another thing that causes that problem is sometimes the ribbon or correction tape gets caught in the printwheel.
Feb 18, 2010 | Swintec 7040 Typewriter
Letters and numbers not printing correctly
It sounds like you have a damaged printwheel. Get a new one and try it.
DickyO
Apr 28, 2009 | Lexmark Wheelwriter 15 Series II...
Printing different letters
take to a repair shop or get a new one, no easy fix for this
Aug 21, 2008 | Brother GX-6750 Typewriter
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Printing wrong letters and numbers
Typing wrong letters.
Please help immediately
Apr 28, 2008 | Brother GX-6750 Typewriter
Erronous letters or numbers
Under the ribbon there is a motor that drives the print wheel try to get some light oil on the front and rear bearings (wd 40 usally works well) its a little hard to get to the rear one.
hope this helps
DickyO
Jan 29, 2008 | Lexmark Wheelwriter 1000 Typewriter
Brother GX-6750 Typewriter Logo
80 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
