Question about Sharp Microwave Ovens
Need part #, price & availability of a replacement "touch" key pad for Sharp model R-9H91
  • Sharp Master
  • 9,086 Answers
The keypads for all Sharp R-9H## models are no longer available.
Once the oven becomes impossible to use, it will have to be scrapped.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
Sharp microwave oven flashes 88:88 touch pad does not respond , model R-9H20
You have a failed membrane keypad.
Replacement keypads are no longer available for any Sharp R-9H-series microwave ovens.
The oven will have to be replaced.
Nov 19, 2016 | Sharp Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    My R-4A58 unit only displays
    The keypad control board will need to be replaced.
    Apr 26, 2012 | Sharp Microwave Ovens
    Sharp Microwave on "Lock" and
    The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
    Mar 08, 2011 | Microwave Ovens
    Buttons don't work
    Hello there:
    This is normally caused by a faulty touch pad that is failing These touch pads are replaceable but they can cost about 60 to 100 dollars depending on the exact make and model ok
    I hope this is very helpful for you
    Best regards Michael
    Dec 11, 2009 | Microwave Ovens
    The clock works & counts down but the microwave won't heat
    • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
    • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
    Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
    Aug 03, 2009 | Sharp R-1460 Microwave Oven
    No numbered touch pad for use setting clock
    I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
    If that doesn;t work, press STOP / CLEAR then try the above again.
    Let us know if it does not work.
    Mar 05, 2009 | Sharp Microwave Ovens
    Sharp carosel micro wave Model R-9h54
    I'm very sorry to tell you that keypads for all Sharp R-9H-type models are no longer available.
    When the oven becomes unusable, it will simply have to be retired.
    Sorry we couldn't bring you better news, but we're happy to help you and we'd appreciate your thoughtful rating of our answer.
    Aug 01, 2008 | Microwave Ovens
    Sharp Carousel Convection Oven. Model R-9H54.touch pad
    It depends on what you mean by "a problem with the touch pad assembly".
    If some or all keys do not respond, you would probably need a new keypad, but the key units for all Sharp R-9H-series models have been unavailable for a few years now.
    These units did indeed last a long time.
    Sorry I can't bring better news.
    Dec 06, 2007 | Sharp R-370E 1000 Watts Microwave Oven
    Microwave Ovens Logo
    35 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
