Question about Vacuums
Wand my extension wand wont slide into place anymore wen im not using my hoover. wat can i do?
  • 328 Answers
Do you have a telescopic/height adjustable wand or just two tubes which have to be stuck together? If they are made of plastic well, it may well be broken. If its metal check that the tops aren't corroded or the handle itself isn't broken. If the tubes/wand isn't sliding up and down (i.e. if its height adjustable) then something has got stuck. Sadly for this kind of repair you'd be better off to buy replacement wands or consider something aftermarket on EBAY. Check the diameter of the tubes with a ruler. If it is 3.2cm (32mm) or 3.5cm (35mm) you can buy replacement tubes. If you can't afford that then try furniture polish on a J cloth or similar and with a stick wedge it inside the tube/wand so that it adds a little lubrication or simply a clog - it sounds like there is dirt clogged in the part that slides. Dont forget to rate, thanks.
Posted on Jul 26, 2008
DC14 arm extension will not lock in place.
I WOULD CALL DYSON TO BRING IT IN THEY CHECK IT FOR FREE FOR YOU, AND WARRANTY IS USALLY 5 YEARS FROM PURCHASE.
https://www.dyson.com/support/warrantyterms.aspx
http://www.dyson.com/support/servicecenters.aspx
May 25, 2016 | Dyson DC14 All Floors Upright Vacuum...
Repair extension on miele vacuum?
My Hoover had the same problem. I disassembled the plug and socket and cleaned all contacts with alcohol, gently compressed the prongs in the female socket with a pair of pliers so they would grip the male pins more tightly, and reassembled everything. If your wand's socket won't come apart, use Q-tips to clean the contacts and a pair of small screwdrivers to squeeze the prongs together. Also, my wand had a some play in it which caused the contacts to loosen up in the first place, so I used adhesive-backed felt strips to keep it from wiggling. So far so good -- I'm at 18 months and counting!
Oct 31, 2014 | Vacuums
Hoover windtunnel, wand does not pick up
Hi, it's Cindy from Crucial Vacuum.
It sounds like your vacuum wand is clogged. A great trick is to remove your wand as per your manual and run a coin through it. If it comes out properly, check the place it attaches, as it may have thick debris. If it does not come out the other end, clear the clog in the hose.
You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 28, 2014 | Hoover Vacuums
After pulling the extension rod up and using the extension attachments i cannot get the rod to go back down,It seems like there is something blocking the rod from going down
Sorry to hear you're having a problem with your DC24. For the correct way to replace the wand and hose after use, you might find it helpful to refer to the user guide supplied with your machine. In case you don't have this to hand, here is an online copy:
http://media.dyson.com/downloads/UK/floorcare/Manuals/DC24_uk_manual_120710.pdf
You should find the wand slides back down inside the hose without resistance, and locks into place with an audible 'click'. If it's not doing this, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US), so we can provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Jul 24, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Can't find info for hoover steam vac spin scrub model # F5905900 on Hoover website, doesn't show that model number at all...looking for mesh (kind of cone/cylinder shape) that goes in dirty water tank (I...
The cleanout tool is part # 43514001. The filter is # 90001398. Be sure to leave a 1/2 inch gap between the top of the filter and the bottom of the lid. If you need a manual, try model F5914-900 0r F5912-900 on Hoover.com
Mar 18, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The self propel switch on my Hoover 7500 wind tunnel is intermittent. How can I repair it?
Hi
You'll need to check if belt is disconnected or worn out. To check, disconnect cleaner from electrical outlet and disconnect power nozzle from extension wands. To remove hood, turn nozzle over and unscrew the 4 recessed Phillips head screws. Note: Do not remove the 3 screws in the triangle formation as these hold the motor in place. Please check the video for details--
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Sep 03, 2010 | Hoover U6630-900 WindTunnel Bagless...
How do you remove brushes and clean under the cover?
I too have this machine. On this particular model the brushes are not removable like on the newer versions. You can either purchase a "cleaning wand" from Hoover OR create your own as follows: Simply obtain a pendaflex hanging file folder (legal size) and remove the metal rods. These rods work exactly like the Hoover wand they try to sell you. They are quite flexible and easily slide thru the clear plastic openings at base of cover. The hooked ends work wonders in removing furballs, hair and other debris that gets trapped under the cover.
Jun 19, 2010 | Hoover F6020-900 SteamVac Upright Vacuum
No suction throught the hose
sounds like its blocked stick the broom handle thru it , there might be something plugging the hose under the bottom at the connection
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Extension arm
Try pulling wand up from hose with machine turned off.
Or are you saying that the wand & handle wont uclip from the body of the machine ?
http://dysonmanuals.llc.nu/
Sep 26, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Where can I find an extension hose and wand for a hoover wind tunnel bagless canister model S3755 (59134002)
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=673664
Generic problem for all Vacuums
Where can I find an
Posted by 1socalgirl on Jun 15, 2008
Where can I find an extension hose and wand for a Hoover wind tunnel bagless canister model S3755 (59134002)
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can check with your local vacuum cleaner dealer and sometimes they have them in stock or they can order them for you. Or you can call the Hoover Factory customer service line and they will get you in touch with the Hoover parts Dept and they can ship you the extension hose and wand need for your vacuum. Please include the Model # and the Serial # so they can get the right item and color. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 15, 2008 | Vacuums
Vacuums Logo
381 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
