Red shadow on PT-56WX33G projection tv
Hello. I have a panasonic projection TV. All of a sudden last night there was a red halo (shadow) effect to the left of everything else. I tried the convergence utility in the menu but could not line it up. I saw some of your other posts and it seems like I might need to replace the convergence IC. Do you think this is my problem? Could you tell me what the cheapest way to fix this would be? I am pretty handy and I do not want to put much money into the TV.
  • 2 more comments
  • gdandy Aug 03, 2008
    Thanks for your help so far.
    I installed the convergence ICs and inspected the resistors (which all
    looked fine). I turned on the TV and the picture was fantastic after
    going through the convergence settings. I turned off the TV and then
    tried it an hour later. Now there was a blue shadow on all the images
    and I was not able to correct the blue through the TV settings. I
    opened the TV up and now one of the resistors looks blown. I assume
    this probably blew one of the brand new convergence ICs that I just
    installed.
    Please help, what should I do now? Replace the resistor and try
    one of the old convergence ICs? I am thinking that since my original
    problem was that there was a red shadow, that one of the old
    convergence ICs is still good. Also, can I get the resistors at radio
    shack? Should I replace only the resistor that looks blown or all of them?
    Thanks. It looks like the R7001 resistor is definitely blown. Should I replace all of the following feed resistors:
    R7001, 7003 and 7005
    which should all be 82 ohm 2watt resistors. The other three are R 7002,
    7004, and 7006 they should all be 120 ohm 2watt.
    Do you know where I can purchase these?
  • gdandy Aug 07, 2008
    After second look I noticed that it was actually resistor r7016 that was blown. I replaced r7011 through r7016 which were all 2.2 ohm 2watt resistors. The TV is working again! Thank you for all your help. You provide an excellent service!
  • gdandy Sep 06, 2008
    Hello, the TV was working fine for about 2 weeks then it all of a sudden turned off. The LCD light on the front blinks 3 times when I tried to turn it on.
    When I unplug/plug the TV back in it will work for about 15-25 minutes perfectly and then shut off again.
    Is there anything I can do to fix this? I tried re-soldering in the convergence ICs but the problem still occurs.
  • 8,617 Answers
The cheapest way is to replace both convergence Ics they are both STK392-110 and you can get replacements at the following link, and they provide free instalation instructions with pictures, plus free online instant messageing while you do the actual repair. Its a very easy repair. Here's the link.
http://servicemanuals.vstore.ca/
Posted on Jul 27, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Aug 03, 2008
    I would recommend changing all the low ohm feed resistors as they are most likely out of tolerance or blown. Your ICs may still be good.
  • Sonny Berry
    I would replace them all as they resistors all have tight tolerances and theres only six of them, so I would just replace all of them. Depending on where your located there may be a large electronic distributor that may have them. They link above should also have them. I am not sure if radio Shack or Frye electronics would have them or not.
  • Sonny Berry
    Sonny Berry Aug 07, 2008
    Thanks, glad I could help
Pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Convergence problem TV won't let me align the
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jun 12, 2010 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Red lines in projection tv
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Panasonic PT-50LC13 50" Rear Projection...
The picture has a shadow, like it's being projected in 3D
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 27, 2009 | Panasonic PT-51HX41 51" Rear Projection...
HELLO OUR 53" PANASONIC REAR PROJECTION TV JUST WENT RED LAST NIGHT AND THEN WENT OFF AND IT WILL NOT COME BACK ON ANY IDEAS. IT TRIEDS TO START UP WITH A BLINK AND THEN OFF AGAIN
This model TV has a gasket on the red picture tube that faces down. The coolant leaks from between the picture tube and the lense assembly. When this happens the red tube over heats and shorts out internally and usually cracks the glass.You will probably find coolant all over the circuit board if you open the back panel of the TV.
Call a good TV Tech to repair this. It will cost over $500 if the picture tube is still available.
Jul 30, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53TW53; Red shadows appear and then the t.v. shuts down.
The convergence output IC's have failed. Only fix is to replace them. These are large amplifier IC's bolted to heatsinks and have a high failure rate in all projection sets.
Jun 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Televison & Video Logo
260 people viewed this question
Top Televison & Video Experts
