FixYa.com
Tags:
Air Conditioners
Generic problem for all GE Air Conditioners
GE UNIT - AC/HEAT PUMP
posted by cheryleaton1 on Jul 26, 2008
DOES IT HAVE AN OVERFLOW VALVE FOR CONDENSATION? IF SO, DOES THAT MEAN THE PC PIPE IN THE FRONT OF THE UNIT IS CLOGGED AND NEED TO BE REPLACED OR CLEANED... WATER IS COMING OUT A SMALL TUBE ON THE UNIT - NOT SURE IF CAUSING UNIT TO WORK HARDER
Comment by cheryleaton1, posted on Jul 26, 2008
how do you clean a unit that is in a closet? It's the central air and heating unit in the home. It does have the PC pipe attached from unit to drain, my question is do they have an overflow valve in which excess water drains? If so, then that will tell me that the original drain process is not working properly.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
textonor
Rank:Guru Guru
Rating: 89%, 91 votes
Hello Cheryl, what they are talking about is a drain. As air conditioners run they collect moisture from the air on the evap(in cooling mode) or condenser ( in heat mode). This moisture will run off the part and flow into the tray. In the cooling mode, the moisture is slung onto the condenser to help cool it down, thus be more effective. I always recommend once a year remove the unit and clean all the coils and oil the fan motor. Household oil will work for this. During this cleaning find and clean out the drain. If it gets clogged that water can run back into the home. The PC pipe is sometimes attached to the unit to direct the water to a designated place. These units are common in hotels and they use the pipe to keep the water from dripping on the guest as they walk under the windows. Hope this helps.
Comment by textonor, posted on Jul 26, 2008
Hello Cheryl, Sorry about that, since you didn't state it was an HVAC system I assumed the window style. On your unit all the water does is drain out. There isn't any overflow as the water isn't used for anything. The plastic pipe is your drain system. They become clogged over time. I use 50 psi of compressed air to blow out the drain, then slowly flush it out with hot water from the tap. Depending on how clogged the drain is, you may have to do this several times. There should be a outlet on the outside of your home where the water goes. I have seen this get clogged at the outlet to sometimes with plant material. Hope this helps.
Rating Locked! (?) cheryleaton1 has rated this solution as Helpful
This Problem Also Relates To: GE Quiet-Aire Ductless Air Conditioning Split System, AS1CD12AA0/AS0CD12AA0 Air Conditioner GE Deluxe AGM05LA Thru-Wall/Window Air Conditioner GE Deluxe AGM12AB Air Conditioner GE Quiet-Aire Ductless Mini Split System Air Conditioner GE Zoneline AZ55H09D Air Conditioner GE ® Built-In Room Air Heat/Cool Unit 230/208 Volt, AJEH12DCB Air Conditioner GE ADQ12AA Air Conditioner
Can you Help with these Air Conditioners problems?
Air Conditioners
need schematic
need schematic Answer This...
Air Conditioners
I have a friedrich through
I have a friedrich through the... Answer This...
Air Conditioners
My Haier 8,000 BTU air
My Haier 8,000 BTU air... Answer This...
Samsung AS18A6RB Air Conditioner
split AC 1200-BTU Kenwood Model...
split AC 1200-BTU Kenwood Model... Answer This...
Friedrich CP06C10 Thru-Wall/Window Air...
A2 - F5
Hello My AC is posting an E2... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
