Question about Sony PlayStation Portable (PSP) Console
Broken psp i dropped my psp ,it came apart. i put it together but it wont work what should i do
    Problem Solver:
  • 9 Answers
Well..
i think since you've dropped..
it..
&& it came apart..
it probably..
doesn't work anymore..
no matter how you've put it back together..
its not going to work again.
sorry =[
Posted on Jul 26, 2008
How does the hansgrohe hand held shower head md # 17850831 snaps together
The 17850 is not designed to be taken apart and put back together. They are pressed together in the factory. If it was dropped and came apart it is most likely broken beyond repair. If you need further help fell free to contact Hansgrohe Tech 1-800-334-0455.
Dec 08, 2012 | Hansgrohe Carlton 17850831 Polished Nickel...
My scroll in my psp is broken
if im not mistaken you are talking about a problem with the directional buttons. if it is that, here's the solution for that. you have to take apart your PSP, you will see where the directional buttons go. you will have to open up the little strip that is underneath the buttons. you don't need to open up the strip completely. get a Q-tip , get it damp with some alcohol, rub the bottom contacts and the upper. after rubbing it with the tip that has the alcohol, you will rub it with the other side of the Q-tip that is dry. after all this is done, you can put strips back together. they don't have to glued back together. put your PSP back together and it should work. see picazzkikronu.jpg
Aug 07, 2011 | Sony PlayStation Portable (PSP) Slim...
My psp wont load umds
the scanner must be broken or have a smudge on it use a q-tip with a drop of water on it and carefully whipe it
Oct 06, 2009 | Sony PlayStation Portable (PSP) Console
I took my psp apart to clean all the soda out of
open it agin then try to put it back together perfictly
Jul 02, 2009 | Sony PlayStation Portable (PSP) Console
PSP wont read games
Did you ever drop it? Usually if a PSP will not read UMD's, either the laser is dirty or it has been moved. If you dropped it, the laser has probably been moved. You'd have to take the whole entire thing apart to move the laser back, assuming you knew the position it should be in in the first place. Even if you have dropped it, the first thing I would do is to pick up a UMD drive cleaning kit for around $10 and try that. If that does not work, I would suggest sending it to be repaired. I hope this helps!
Jun 05, 2009 | Sony PlayStation Portable (PSP) Console
Wont turn on after being dropped in toilet.
There might have been some water in the circuits. try taking it to the game store for repair
May 16, 2009 | Sony PSP-3000 Silver Console
Memory stick won't go in
The only way that I know of is to dismantle the PSP or send it in for repair. Taking the PSP apart is a very long process and although it is reasonably easy, the screws can easily be lost and it is easy to forget where everything goes when putting it back together. I would reccomend putting a small screwdriver in the card slot to find out if there is something stuck in it but you cannot tell what you are doing and the contacts for the memory stick are quite fragile and you could easily damage them.
If you are prepared to take the PSP apart then post a comment and I can guide you throught the process.
Hope this helps
Mowcius
May 16, 2008 | Sony PlayStation Portable (PSP) Console
Power problems
Hi Gohan102,
Open the battery compartment, and remove the battery.  Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light,  If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp.  If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment.  Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
Psp
is it a scratching scrapping noise?
as some UMD cases, as in the plastic thing around the disc colapse or come apart this stops the disc spinning properly.
Check the plastic on the UMD... click any sides together that may be loose / or make sure the case isnt pushing on the disc.
Also open the PSP, hold it upside, gently shake it & blow into it.
Put the UMD back in & try again.
Oct 03, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
