Question about Akai LCT3201AD 32 in. LCD Television
Doesnt respond to remote
I cant get any remote to work with this TV Ive tried Akai, Phillips Universal,Sony Universal but nothing works.
  • 689 Answers
Make sure that you have entered correct code, each device you are going to use you need to program it. You can use code list if you still have. If you dont have code list after obtain the model number you can search the appropriate codelist online resources such as http://www.remotecentral.com/
Please don't hesitate to post more if you need more help.
Good Luck
Posted on Jul 26, 2008
  • Akai Master
  • 19,396 Answers
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Akai Reomte has stopped working, Universal Remotes will not
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Jun 25, 2009 | Akai LCT3201TD 32 in. LCD Television
Akai 42" plasma tv i need replacment remote
Dec 08, 2008 | Jensen JER-422 Universal Remote Control
Remote to my tivo won't work my on/off and volume on Akai TV
Nov 16, 2008 | Tivo DirectTV Remote Remote Control
Universal remote
Akai are notorious about remote incompatibility
Aug 07, 2008 | Akai PDP4225M 42 in. Plasma Television
Cant get universal remote to work with broksonic tv
To purchase a replacement try this site
Have you tried these codes? 0236, 0003, 0463. If the remote only uses 3 # drop the first.
Mar 13, 2008 | Broksonic CTVG-5463GVC 19" TV
Borken remote; universal remote doesn't work!
I have had on order since December 2007 the Akai replacement remote #WIR3500001-EQ01 the Akai TV/DVD combo model #CFTD2011. I called each month for 5 months, being told each time that it was on backorder. A few days ago, I received a letter in the mail stating that this remote is no longer made and is not available.
I too have tried universal remotes without any luck. If anyone has a resolution, it would be greatly appreciated.
Nov 19, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
My tv/video button
Not sure if this remote supports TV/VCR button. You might have to try anothers companys universal remote. Like sony universal remote for sony TVs Phillips universal for Phillips TVs ETC... Hope this helps. : } SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 16, 2007 | One For All URC-3021 Remote Control
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Akai LCT3201AD 32 in. LCD Television Logo
56 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
