Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Won't spin or agitate
Strange whurring noise when it is supposed to agitate or spin. Drum and agitator do not move during respective portions of cycle. Water in/water out works fine. Cycles seem to work fine. I suspected a coupling based on research here. Dissassembled and found a perfect coupling. Where do I go next?
  • 1 more comment
  • katigear Jul 26, 2008
    Whirlpool ultimate care 11, that won't spin or agitate. Makes a quite humming sound and has an electrical smell. Gets hot underneath, and the drive coupling tries to move, but nothing.
  • Anonymous Aug 05, 2008
    washer drains but wont agitate or spin
  • klap14 Aug 09, 2008
    Washer won't agitate or spin but makes loud noise. Water in/out works fine.
Sounds like a burning out motor to me...
Posted on Aug 02, 2008
Won"t spin or agitate. Makes a loud rattling noise
If this is a Whirlpool manufactured TOP LOADER (such as Roper, Estate, Kenmore, Amana, and Frigidaire), you may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. Common symptoms include the following:
1. No spin or agitation.
2. Washer will fill and empty.
3. Drive motor still runs.
4. Strange rattling, grinding or clicking noise during agitation or spin cycles as the drum sits still.
If your washer is exhibiting these symptoms, then its probably a safe bet that the motor coupling is bad.
The following link explains how to replace one:
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Dec 17, 2010 | Kenmore 24032\24036 Top Load Washer
In the spin cycle, my washers agitator spins but not the drum. Aren't they supposed to spin together? Also alot of knocking or clicking noises
yes in the spin cycle the agitator and bowl lock if not clothes ball up and machine goes out of balance check the spin coil or electric damper is activated during spin cycle if not replace if blown or open circuit also clutch arm cold be broken have a close look keep me advised
Nov 05, 2009 | Washing Machines
Washer makes noise during spin cycle, wont agitate
Sounds like your transmission is going out. Yes washing machines do have transmissions, I know, strange huh? Anyway, the transmission is connected to your motor and the motor makes it spin and agitate. The transmission goes up into the tub and is basically the agitator. When the gears go bad in it, it will start making a loud noise almost like a grinding noise and won't spin properly or agitate. It is expensive to fix, almost as much as a new washer. Your best bet is to buy a new machine unless you can find a good deal on a refurbished transmission. Those will sometimes run only around 150 dollars. A new one though will cost you around 250. You might be able to find a good deal though. They are easy to fix, I myself replaced one in 15 minutes once when I was still a repair man for Sears. So, check out some prices and see what the best way to go is for you. If you have any questions about installing it let me know and I can give you an easy step by step walk through on it. I hope this helps you out and good luck.
Jan 22, 2009 | Kenmore 15864/15862 Top Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Kenmore top loader washer noisey agitator
it sounds like the gear dogs in the agitator. pop he top of agitator and check. its a easy repair.
Aug 28, 2006 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
144 people viewed this question
Dan Webster
Dan Webster
Sal De
