Panasonic CT 32SC14J 32" TV Flickering Problem
Hi all-
I'm having a weird problem with this television. I bought this TV set used and when I did saw the picture on cable at the seller's home; it was splendid. Brought it home and hooked it up to Dish Network and now I'm having a flickering issue, the picture has a whit flicker every few seconds no matter what I use as an input... I've tried both s-video and component, same flickering problem. The set has three different video inputs and I've tried all three, same problem. Ordered a very pricey s-video cable, tried that as my hookup but it didn't change a thing.
I also have this TV hooked to a DVD player via component; here's the thing... NO flicker, the picture is wonderful for a CRT television. I also have a Hitachi rear projection set that is hooked to my Dish Network receiver, no issues whatsoever. What could be the issue here? Incompatible with my dish feed? A problem with the TV? RF frequency problem?
Thanks in advance for any input :).
Lou
  • Anonymous Dec 14, 2008
    i have the same problem with my sony tv. please notify me when u find a solution.
5 Suggested Answers
  • 71 Answers
SOURCE: CT-32SC14J Panasonic
unit has a fuse inside. be sure to unplug set from ac before opening
Posted on May 28, 2008
egadgetguy
  • 258 Answers
SOURCE: Picture settings messed up!
Loose cable or wrong setting. Channel, input type, etc. Also. make sure the audio isn't plugged into the video input [either end]
Posted on Aug 14, 2008
SOURCE: flickering image
I have a vcr and dvr combination emerson tv a 27 inch and sometimes while playing it will flicker and these horzion lines come in while a program is runing, and then the sound goes way down then comes back up to normal.
can you give me a answer?
Is it my picture tube it is about to go out?
It is close to five years old
Posted on Oct 13, 2008
SOURCE: Toshiba CN36X81 television.. NO Sound...
IF coming in via, the "Dish" networked receiver, please check that this volume is turned way up, on the TV. and then control the the Volume, with the Dish Remote, often this is a problem, as one is turned down, and the other cannot turn that up, simply try syncing the Volume controls, UP on TV, control the Audio with dish remote. thats all i can think of. Check by feeding a signal IN from an AV, source, ie: Yellow, Video, & Red& White, Audio. Turn TV UP and check, IF it responds to this all is well. If NOT then you do indeed have a fault, with the TV.
Posted on Mar 27, 2010
No image from coaxial cable or any of the video inputson a panasonic CT-32G34
you have to have the TV set to the right input, look on your remote for input selection. Or try changing the channel on your TV
Feb 07, 2010 | Panasonic CT-32G14 32" TV
How to unblock v chip in panasonic panasonic CT 27SL15 TV
Push the power button and the action button on the tv set until it shuts itself off and this will reset your tv. You cannot use the remote to reset...must use the actual tv buttons on the television set.
Jun 17, 2009 | Televison & Video
Need user guide for Panasonic 32'' TV model CT 32SF37B
I have a user guide which consists of 21 pages. FYI, you can contact Panasonic Consumer Electronics Company, Division of Matsushita, Electric Corporation of America --- One Panasonic Way, Secaucus, New Jersey 07094 or email - www.panasonic.com
Mar 26, 2009 | Panasonic CT-32SL14 32" TV
Blurry Screen on Panasonic CT-32HL44
I solved my problem. Apparently the RCA cables where missing with the image. So I bought some Component cables and that fixed my problem.
Dec 30, 2008 | Panasonic CT-32HL44 32" TV
Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
May 28, 2008 | Televison & Video
do you have any electronic skill ????
Jul 20, 2007 | Panasonic CT-32SL14 32" TV
Panasonic CT-32SF35 32 On & Off, On & Off
Bad capacitors in the standby power supply most likely.
Jun 09, 2007 | Panasonic CT-32SF35 32" TV
Televison & Video Logo
264 people viewed this question
Top Televison & Video Experts
