Question about Celestron Advanced C102-HD (241 x 102mm) Telescope
CG4 Drive controller
Hand controller unit dropped form my hand with no visual damages seen from out side. But it no more drives the telescope though while connecting with the battery pack the middle light (supposed to be in green during sidreal movement) is on in yellow mode.By touching the motor I feel the pulse that the controller delivers to the motor but very unfortunately it is not driving the telescope. Can you provide the circuit diagram? I've purchased this telescope last year from Adorama and brought in India this year.
Biswajit
  • 3,186 Answers
I already answered this question.
Posted on Jul 09, 2011
Porsche 928 problems
should be located in the passenger side footwell though being that your one right hand drive may be in the drivers footwell behind the side plastic should look something like this
Jan 15, 2014 | Cars & Trucks
I have a DS-2000 Series Refracting telescope, it will automatically go up and down with the hand held computer, but will not move side to side.
You DID tighten the clutches-- and you do have fresh batteries in the scope?
Either the hand controller buttons are broken or you have some kind of damage inside the scope base-- or a blown circuit board on that motor.
Sep 05, 2011 | Meade DS2130ATSLNT (296 x 130mm) Telescope
Is there an user friendlier hand controller available for the Ultima 2000? Does the wedge make much of a difference?
The wedge is only used if you take astro-photos. You do not need it for visual observing.
Contact Celestron support about the hand controller here:
http://www.celestron.com/c3/page.php?PageID=37
Sep 29, 2010 | Celestron Ultima 2000 -- 8 Telescope
Celestron Nexstar 114gt telescope,hand controller lights up only
Do you have a fresh set of batteries in the scope? Better to use an outside 12 volt power pack with the Celestron 12 volt "cigarette" lighter cable.
This can be three things:
Low power
Bad cable from hand controller to scope.
Or a broken hand controller
Try fresh batteries first.
Dec 31, 2009 | Celestron Optics
The hand held unit lights up when turned on, and the telescope "homes" but the LED does not show anything. The voice speaks "Bushnell Northstar" but very quietly. The telescope can be moved by the bottom 4...
Can you reverse the cable end to the hand controller-- a bad cable can cause this. Also low power supply, depleted batteries can also cause this.
Return the hand controller for replacement if batteries and or a new cable do not fix this.
Dec 24, 2009 | Bushnell NorthStar 78-8846 (675 x 114mm)...
A friend gave me a tasco telescope st-60700ct with no power.
Read this---
http://www.fixya.com/support/t379841-tasco_starguide
Jul 19, 2009 | Tasco Starguide Computerized 80mm...
Celestron CPC 800 frozen display in the Hand Controller
I've seen a couple of things cause this problem. Both can probably be fixed by you.
The first thing to try is to look at your power connector on the telescope. You'll see a pin sticking up with a split in the middle. Take a small knife or screwdriver and very gently pry that **** slightly apart. I've seen where that compresses and it becomes intermittent.
The other thing I've seen is an intermittent connection between the hand controller and telescope. This can happen on the controller end or telescope end. The AUX ports will work for the hand controller too. Try it in those ports and see if things improve.
If they don't, then you could have a loose connector on the hand controller. Mine was bad enough that if I wiggled it the controller would either go blank or lock up. I fixed mine by getting a telephone crimp tool and crimping it. It's worked fine since then.
You may also wish to check out the CPC group on Yahoo Groups.
-jodair
Apr 02, 2009 | Celestron CPC 800 Professional...
Meade autostar hand unit fails after 2 seconds changed hand units
You damaged the circuits inside the hand controller-- unless you are an electronics whiz these cannot be repaired.
However you can find them for sale directly from Meade and on Ebay (used) usually for about $80.
Mar 04, 2009 | Meade 494 AutoStar Telescope Control Unit...
Azimuth Drive failure on Nexstar 114
Hi Dan, before you ship it off somewhere, you may want to try and change out the hand controller with another one that someone has and see if the problem moves.
Nov 25, 2008 | Celestron NexStar 114GT (269 x 114mm)...
Hand controller not working
You have broken something inside the hand controller-- the computer is in the hand controller NOT in the telescope. Contact Celestron for a replacement hand controller or advice.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Jul 27, 2008 | Celestron Advanced C102-HD (241 x 102mm)...
Celestron Advanced C102-HD (241 x 102mm) Telescope Logo
70 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
