Question about Whirlpool Duet GHW9150P Front Load Washer
F-05 flashes
Washer will not start cycle and F-05 flashes on LED read out
  • 5,911 Answers
The following link expains the "F05" error code:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Check to see if the connector is still plugged into the heat sensor, first. I have seen where the connector has come loose and caused this error code. If not, take the resistance readings as recommended. I hope this helps you.
Posted on Jul 26, 2008
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
F-05 flashing on the display screen
Hi There
I have this for to read and hope this helps out. Let me know how this works out.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Thank you for writing to fix ya.
Best Regards Richard
Dec 28, 2009 | Washing Machines
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
Nov 30, 2017 | Indesit W 123 Front Load Washer
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Please rate my solution.
Thanks.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
Mar 15, 2009 | Hotpoint WMA31 Front Load Washer
My dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Nov 29, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
345 people viewed this question
Dan Webster
Dan Webster
Sal De
