Question about Jabra BT350 Bluetooth Headset Headset
Jabra does not charge - no lights
I have had my Jabra for a couple years now and it has charged everytime. I plugged it in the other day and there was no charging light and even after an hour there was not charge on the headset. I had not used it for a couple months. Not sure if there is anyway to get it working again. Any suggestions?
  • 3 more comments
  • Anonymous Aug 05, 2008
    it wont turn on???
  • test981 Sep 29, 2008
    Out of the box Jabra BT350 won't charge
  • ohmaistars Nov 07, 2008
    I have the same problem. I haven't used my headset in a while, and tried to charge it tonight; when I plug it in it flashes green then red really quick then nothing. The blue light doesn't appear anymore and it doesn't appear to be charged at all. Any suggestions?
  • blazersc Nov 15, 2008
    Out of the box BT350 for my wife's birthday will not charge either.
  • Anonymous May 05, 2009
    same thing !!!!
All of these solutions just sya mine doesnt work either. No **** it doesnt work, why would i be on this website if it worked. I want solutions not pansey namsey whiners.
Posted on Feb 07, 2010
Change the battery
Posted on May 06, 2009
I have the same problem... I've had a bluetooth for 2 years and now I'm deciding to use it and it wont work, ill plug it in blue light comes on quick then shuts right off.
Posted on Nov 15, 2008
I had charged my bluetooth next day when i tried to use it the blue lights appear but it doesnot connect to my phone. i don know wat is wrong is it, it need to be charged again or got problem with my bluetooth. any suggestion
Posted on Dec 24, 2008
Jabra extreme2 will not charge
All things can go defect. But to find out if it is your charger, cable connector or the battery you have to look very close. Perhaps you even try another charger and or try to charge an other headset.
When you are using this one for a couple of years now, day by day, perhaps it is time to start saving for a new one?
Jul 21, 2014 | Jabra Extreme2 Bluetooth Headset
Why can't I turn on my Jabra sport after charging?
Could be. No battery has a lifetime forever. But perhaps you did not unplug it correct?
Try plugging it in and look if any light goes on when plugged in on the charger. You don't need it on the charger for a long time. Then unplug it an try to start it again. also check if all contacts on the Jabra and on the charge cable are clean and nothing can block the current.
May 23, 2014 | Jabra SPORT Earset
Jabra wave battery suddenly won't charge
The battery may be shot and incapable of charging. The red light could be merely indicating that the charger is working.
Jan 13, 2014 | Jabra Wave Bluetooth Headset
Jabra sport will not charge
Same problem did you call the 800 number?
Dec 09, 2011 | Jabra Radio Communications
I have a jabra bt250. I put into the charger one
A search on here will get the answer I found it once it. is the battery and headset needs to be opened and 'jumpstarted' it is non replaceable though.
Sep 24, 2009 | Jabra BT250 Consumer Headset
Steady Red Light
From the sounds of this.. It's all due to bad keying of the polarized charging plug. The solid red light PROBABLY means you're battery is pretty darn dead. It'll need a new battery(not worth the cost imho. get a new jabra, and be happy once again) At a certain low voltage, the red light starts blinking. when it drops below the preset threshold, it will shut off completely. If it sits too long at this discharged rate, the battry WILL self-terminate. If the voltage drops below a certain level, it's ruined. Also note, most Li-ion cells will only last a few years. 2-3 years of "full power" is usual. Mine's 2 years old(steady usage), and showing signs of it's age.
"My red light won't go off even though I charged it all night.
Also, a small piece of plastic came off the charge opening. I don't know if this is will pose a problem to the use of the Jabra BT150."
This is probably the most telling bit of information. It means you DID plug the charger in upside down. It will NEVER charge in that configuration, as it is supplying power to the completely wrong pins. If the battery was good to start with, it shouldn't hurt the headset, but never know. I have accidentily plugged it in backwards for a couple min before noticing, with no ill efect, but YMMV.
"Doesn't anyone from the Jabra manufacturer check this site?"
NO (especially not for discontinued products)
Oct 05, 2007 | Jabra BT150 Wireless Headset
Jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Sep 28, 2007 | Jabra BT250 Consumer Headset
Jabra BT500 will not power on or charge
I would also like to know if you find a fix for this problem. I have the BT500 and it will also not turn on.
Sep 17, 2007 | Jabra BT500 Wireless Headset
It wont charge
these headsets are cheaper nowadays, its not worth a repair, depending on your country you can get jabra or motorola types for around £35 GBP or $70US
Sep 02, 2007 | Jabra BT150 Wireless Headset
Jabra BT350 Bluetooth Headset Headset Logo
1,675 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
