Question about Whirlpool Microwave Ovens
What would cause the touch panel display screen on our model gh6177xpb3 microwave to not function - the panel lights up - the lower controls seem to function properly - Thank-you in advance for your assistance.
  • Whirlpool Master
  • 9,098 Answers
It may be a glitch that can be corrected by a hard reset. Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
It may have gotten moisture, contamination, or grease inside, which can happen if one cooks on the stove top without having the microwave's hood vent fan on.
It may simply need repair.
We repair microwave control units and touch panels / touch screens for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 02, 2008
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Upon plugging in the microwave, several beeps are heard and the touch screen displays "Touch Error". After a few seconds the error message goes away but the touch pad is not functional. The Kenmore model...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a full one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 08, 2010 | Kenmore 63792 Microwave Oven
Touch screen fading in & out, unit works fine
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Jul 27, 2010 | Dacor DMT2420SS Microwave Oven
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
Feb 24, 2010 | Microwave Ovens
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
My microwave panel is not working.
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
Mar 18, 2009 | LG LMVM2055 Convection/Microwave Oven
Error Code
I would recheck the control board installtion that you made, as well as verify that you got the correct replacement. Also the board may contain static sensitive componets so you might want to make sure you are grounded when handleing the control panel. Good luck
May 14, 2008 | KitchenAid KHHS179LSS Convection /...
Microwave Ovens Logo
331 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
