Question about SanDisk Sansa e250 MP3 Player
SANDisk Reset Hello.. I am having the same exact problem you were having. Can you tell me how you solved it?
  • 758 Answers
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Jul 31, 2008
I have a 2 g memory card which when full I uploaded to my PC and then deleated all photos from the memory card I tried to use this card again but the camera tells me the memory card is full also it tells...
Exactly the same problem occurred with my San Disk 1GB micro-SD Memory Card. And I solved this problem formatting my micro-SD Memory Card using a software which you can download by clicking here.
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the installed "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
That's all my friend. This solved my problem and I hope this helps you too.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 11, 2010 | SanDisk 2GB microSD Memory Card
Mp3 powers on and is in "lock" mode, then powers itself off. USB, no batteries. How do I correct this problem? Crappy office depot brand called ATIVA...
Hello :
Did you try resetting ? Resetting should solve the problem .
If resetting didn't solve the problem , then try replacing the battery .
If replacing the battery didn't work also , then I recommend you to take it to the service .
good luck .
please rate !
Apr 01, 2010 | SanDisk Sansa m240 MP3 Player
Hello-I lost my manuel on Sansa e250 MP3 player. Please tell me how I can delete songs I no longer want. Thanks.
The manuals are here http://kb.sandisk.com/app/home choose the exact product and that should produce a link to various items, firmware etc and a user manual
Mar 28, 2010 | SanDisk Sansa e250 MP3 Player
FAT is corrupted
Thank you
Computerrep
Jan 28, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa 8gb keeps saiying connected even when its not connected to the computer how do i reset it?
Hold in the power button for 15 seconds usually works - check your manual or Sandisk's website, because they will definitely tell you how to reset it. I cannot tell you without knowing your exact model #.
If it keeps freezing, even after you reset, get the firmware upgrade from Sansa.
Jun 23, 2008 | Audio Players & Recorders
Hello
Just reset ur player using the reset pin available on the player!!
Apr 05, 2008 | SanDisk Sansa e250 MP3 Player
I need to download the program for windows 98
exactly....tell me what exactly you need......
Mar 17, 2008 | Computers & Internet
My e280 sansa mp3 player is not working.....help please....
There is a problem with the device firmware itself..you can try to reset the player by holding the power button down for 15-20 seconds or until it resets....the latest firmware for the e280 resolved much of the freezing issues....also there are two modes for you to use the e280 the msc and mtp.....try deleting in mtp mode....if that doenst solve it...just go to the sandisk site to get a firmware upgrade done...and that would solve the proplems..
Jan 02, 2008 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
