Question about Crosley CFFH10W Top Freezer Refrigerator
Water from defrost cycle going into refrigerator
W
water goes into bottom of refrigerator and has to be mopped every day.I assume something is plugged, but don't know where.
  • Anonymous Aug 03, 2008
    adsf
Ever find out, I have the same problem.
Posted on Aug 03, 2008
I just had mine checked out today. it could be the fan. if you open up your freezer, take everything out and open the metal panel you will see the cooling system. their is a small fan right above the condenser. The freezer part of my refrigerator was dripping water down and freezing up as it reached the bottom near the condenser. Basically the top portion of the freezer wasnt working because of the fan which also affected the refrigerator. hope this helps
Posted on Aug 21, 2008
The fridge is leaking water and going onto the floor underneath the fridge how can l fix this problem
If equipped with Ice Maker and water dispenser we can assume that the water feed has developed a leak. To confirm protect the floor in-front of the machine pull the machine out from the wall and reach around behind and turn off the water feed. CAUTION the wheels from a full machine will scar the kitchen flooring. Mop up the water and dry out the floor.
If the water no longer returns than you can assume that the source of the water is with the ice maker or water dispenser.
If the water continues and the machine operates normally (freezer below 10 F and refrigerator < 40 F) then it is the defrost cycle. The good news the ice maker might be alright. The defrost cycle has a drain tube. About twice a day or less often the machine has an automated defrost that allows for the ice build up on the evaporator coils to melt and run through a tube to a tray under the machine. the water in the tray evaporates between cycles.
First check if there is any water collecting at the bottom inside the refrigerator portion of the machine. If so with the water turned off you can be certain that the defrost cycle water is not being contained with in the drain tube. It is common that the drain tube can either plug from lint etc or ice over, Included i will link a few videos describing the situation and depending on your model a course of action.
How to Unclog Refrigerator Drain Line
https://www.youtube.com/watch?v=4SEe5z9JrMU
Jan 10, 2016 | Refrigerators
Water collecting in bottom of freezer
Unblock the drain hose. You may have to access it from the back of the unit and it may be frozen up so you may have to fully defrost the freezer
Apr 30, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Our 2652 model freezer is working, but the refrigerator is not cold. What can we do?
The defrost drain is blocked..This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle.Seems like it is blocked with water or ice.
Unplug the refrigerator, empty out the freezer compartment
pull off the back panel or the bottom panel (in the freezer compartment) Look for that defrost drain hole..
pour small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. Repeat this until I get the water to go down the drain tube..
Hope this works.
Jul 07, 2011 | Dometic RM2652 Refrigerator
The freezer is cooling but the refrigerator is not cooling
hope this help......
Jul 28, 2010 | Haier HRF10 Top Freezer Refrigerator
Water in bottom of refrigerator
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Jul 07, 2009 | Refrigerators
GE side by side Refr. water leaks under freezer side. seems to be connected to defrost cycle. water can be mopped up with paper towel. put small pan under fridge but does not capture water. Does not leak...
The drain is clogged in the freezer. Take off the back wall inside of the freezer, there is a drain in the bottom, use a turkey baster and hot water to clear all of the ice, pour hot water into the drain, put a piece of weed trimmer line down the hole and try and push the obstruction through, do not use a coat hanger or wire, you will puncture the drain tube and make bigger problems. Finish by pouring more hot water in and making sure it all goes down.
Jun 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
WATER IN BOTTOM OF FREEZER/TURNS TO ICE FRS28XGCB
its probably the automatic defrost cycle.there should be a drain in the bottom of your freezer,and it must be clogged.The automatic defrost keeps ice from building up in your freezer by melting it,and letting the water run out the drain.If the drain is blocked by something or clogged the water collects,and refreezes.You need to unblock the drain.
Mar 20, 2009 | Frigidaire Refrigerator Light Switch -...
Kenmore refrigerator problem
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube. Do this and all will be back to normal..
Regards,
Sai.
Jun 12, 2008 | Kenmore Refrigerators
Zanussi fridge freezer frostfree ZX 57/3 W not working
Hope this helps,
Sai.
Jun 12, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
Refrigerators Logo
209 people viewed this question
Top Crosley Refrigerators Experts
Charles T Nevin
Charles T Nevin
fta777
Colin Stickland
Colin Stickland
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
