Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Mr. Slim MS12- Mold Problem
The unit is 12 years old and while it was supposed to be serviced yearly, the barrel fan has a terrible accummalation of mold which spits out on everything below. The cover comes off but the grill iin front of the fan does not and you cannot get to the fan to clean it. Tke lines prevent removal from the wall for cleaning.
  • 1 more comment
  • Runtty Aug 29, 2008
    Air Conditioner spits out pieces of mold on everything below. Can't get to fan to clean and since it's stationary can't take air conditioner down or take apart. Cleaning with a hose as suggested is certainly not acceptable since the air conditioner is inside my home. I clean the filters but that doesn't help the problem.
  • kelsmck Sep 07, 2008
    the unit spits black pieces all over and has mold all in the unit. i feel it has made me sick all summer. i have no idea how to clean this unit!
  • Heather Rivera Dec 25, 2008
    I have the same problem with my MSZ-A24NA system and I am desperate to get it cleaned. The smell kills my throat. Please if anyone has any idea how to take this apart to enable you to clean it I would greatly appreciate it!!
The barrel fan comes out with a few screw removals I know I just did it. It was not really that bad of a job once you know how it comes out. First, remove your front facia piece which clips in at the very top in three places and two screws under the little white covers down below the unit. Once the face piece is removed, look on the left hand side and you will see two screws. Remove the screws and wiggle that end of the evaporator a little and push the evaporator straight up. Once that end of the evaporator comes loose, you should have enough room to remove the drip pan/vane piece. While you are holding onto the drip pan/vane piece detach the drain line from the drip pan/vane piece by lifting up on the little grey piece on the line and pull the drip pan directly outwards which should remove the drip pan from the drain line. Once the drip pan/vane piece is removed, look into the barrel fan on the extreme right hand side and you will see what looks like vane that are missing from the barrel. This is a hole to access the phillips screw that attaches the barrel fan to the motor. Unscrew the screw a few turns and then go back to the left hand side of the unit and pull the barrel fan forward from its mount. You will have to pull the evaporator forward and maybe a little upwards to slide the barrel fan from out the bottom/left hand side area. Take the barrel fan outside spray with bleach, let it sit in the sun for about 10 minutes and then blast all the gunk out with a water hose. Then reverse the order of assembly and then there you have a clean blower fan pushing more air.
Posted on May 20, 2012
  • Thomas M
    Thomas M Jun 25, 2015
    Do you have any idea how to remove the fan after you remove the set screw and it still does not come off, no matter how hard I pull, Thanks
I have had to clean mine on a yearly basis. On mine once I have the cover off, I can remove a couple more screws, disconnect the baffle motor and the drain connection and pull the drain pan off to gain access to the barrel fan. The first time I cleaned it with a small bottle brush and bleach water. I scrubbed each fin individually, alot of work! I used a pressure bottle(for the garden with wand) to rinse the fan. Then the next year I used a Shark Steamer to clean and kill the mold, still alot of work but easier then scrubbing. I am going to try rinsing it more often with white vinegar to kill the mold.
Posted on Sep 17, 2008
  • Thomas May 20, 2012
  • 43 Answers
I find that spraying it with a lysol stops the mold groth... spray it near the air intake for a bit...
Posted on Jun 25, 2015
    New Friend:
Thanks Thomas. I was amazed how dirty my fan was after less than 3 years. Your directions are spot on. I also had to remove 3 screws on the right to angle the motor a little to pull the fan out. This requires removing the electric control box which is just clipped in at the top and right side. No need to disconnect wires. Just be able to move it out of the way to get to the screws. A little confusing to do the whole job the first time. Next time I think I could do it in 1/3 the time.
Posted on Jun 20, 2013
  • 1 more comment
  • Thomas Jun 21, 2013
    Spray Lysol antibacterial aerosol spray into the top of the unit once every two weeks to limit mold growth on the evaporator and the barrel fan. I also spray it on the barrel fan just as the unit shuts off before the vanes shut. This limits mold growth greatly for me!
    Forgot to tell you to spray it into the top while the unit is running therefore it will get dispersed everywhere within the unit. I spray it for about ten seconds on the top and to reinerate, I also spray it all along the barrel fan just before the vanes shut when the unit is shutting down.
  • cole Jun 21, 2013
    Great idea. Thanks
  • 143 Answers
You are either going to have to move the lines or clean it where it stands. Us air conditioner guys clean those fans with a garden hose. Very messy!
Posted on Jul 26, 2008
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
May 27, 2014 | MR SLIM Split-ductless: Mitsubishi...
Mitsubishi mr slim compressor fan won't turn off
The outdoor fan is supposed to be on almost all the time if the indoor unit is on. It is designed to do this due to energy consumption is from the start of motors. These fans use nearly no electric about as much as a light bulb. If your unit is cooling and no problems have occurred then its probably doing what is supposed to
Jul 26, 2013 | Heating & Cooling
Black mold inside unit, fan becoming noisy, I have a hunch that it,too, is covered with black mold.
It sounds like you know the problem and the sollution is to clean it. these system require rutine cleanings every 6 months because they have condensation always in the pan
Aug 24, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim Model PEH3VK no air in one zone.
The Zone controller needed replacing so I rang for a Serviceman
Jul 06, 2009 | Mitsubishi Heating & Cooling
Display E4 code then only normal air blow in the room
check your cap also you may have a bad condensor fan
Feb 21, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim MSY-A17NA noisy interior fan
If the inside fan got loud because it developed mold, the only cure is to keep cleaning it.
Jul 12, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Moldy smell to air
I have a maytag ac unit that kept smelling moldy. We tried spraying with antifungal, only helped for a short time. I took the unit (ac unit slides out of window case) outside and carefully removed screws only to discover the fan was covered in mold!!!! Oh my what a horrible discovery! I washed the fan blades with bleach and water mix. I completely and carefully washed and wiped down the air conditioner careful around the control box. Then I let the unit sit outside in the sun untill completel dry. Good bye mold and fresh clean cool ac!! I will do this each year now that I saw that ugly mold!! That is definetly a health hazard! I would reccommend you either thouroughly clean your unit or pay someone to do it or get a new unit right away!! Don't use that moldy unit another day!! Good Luck!
Oct 03, 2006 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
3,813 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
