Question about Mitsubishi WS-55859 55" Rear Projection Television
Green Screen Getting a green screen where the picture is very very faintly made out behind the green. Audio still works. Any ideas of the problem? Mits WS-55859
  • Anonymous Jul 30, 2008
    My 60" just did the same thing... any answers yet?
Did you find out anything? Mu 60" is doingthe same thing.
Posted on Jul 30, 2008
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
My monitor screen is black. The green light is on but black screen
The green light usually indicates that the monitor is getting a signal.
The lack of a picture is an indication that the monitor itself is having a problem. I would test the signal with another monitor if you can get one.
I suspect that the monitor backlight has gone bad (if so, you can see the screen very faintly if you shine a light on it).
Or, the screen circuitry has gone bad.
Jun 30, 2011 | Computers & Internet
Samsung Sync Master 914 has no picture. When power supply is only in, green light flashes slowly. When both power and vga are in, green light flashes more quickly. I hear a faint clicking sound coming...
I would check the caps with ohm meter. Make sure they all show increasing resistance. Caps can be bad without looking bad. Check output voltage on the power board, should be around 12V. If all that checks out then I'd look next at the backlight bulb. I'v repaired many monitors and the problem was almost always overheated caps on the power board. Post back and let me know.
Dec 03, 2009 | Computers & Internet
Green Lines with Picture behind
Could be serious...but first check the screen modes (for split screen, format, etc) to be sure the tv is set up properly for the picture you are trying to watch. Switch the input to a DVD or something similar. Is it the same? If not, you have a mode/resolution problem with the tuner and perhaps some other device.
Jun 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have no picture, only green screen and audio when I turn on
i have no picture the sceen is green but i have sound can u help thanks.
Jun 06, 2009 | Polaroid FLM-2011 Television
Green Screen instead of Blue
Check the picture settings on the tv, if that is not the problem, then check all of your connections (RGB cables+RW Audio) that is HD component, if you have both HDMI and HD component then try one of them, or it may be a switch in the back of the DVD player or TV
Jan 11, 2009 | Miller TELEVIDEO 995 TERMINAL W/ GREEN...
Second screen won't work, red light on, no green light.
ITS PROBABLY THE AV CORD IT'S SELF THE SAME THING HAPPENS TO ME BUT GOOD LUCK GETTING ANY REPLACEMENT PARTS ITS LIKE THEY DON'T EXIST?
Aug 26, 2008 | Disney D7500PDD Portable DVD Player
JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
Jan 30, 2008 | JVC AV-56WP30 56" Rear Projection...
Green television screen on a princess tlevision
can you clarify that are you seeing white bright lines on screen & is there faint picture with green color?
Sep 16, 2007 | Televison & Video
Red spot in the middle of the screen
You most likely have a burn in on the surface of one of the picture tubes. What you need to do to confirm this, would be to take off the front screen, and with the set turned on, look directly into each one of the lenses, and see if you see a mark on the green or the blue tube. if this is the case, and I am pretty sure it is, the picture tube will need to be replaced, but this set is not a young thing, as the green faint lines is most likely a bad capacitor in the screen drive circuit. If the picture tube is indeed burned on the surface, most likely be better off buying a new TV set. Good Luck
Jun 25, 2007 | Toshiba 42H83 42" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
