B and O beogram 1700
Works perfectly on 45 speed..... will not Turn / 33 speed....It will pause... I was wondering if I can change the face plate out of a 2402 and servo motor / control panel will it work? or whats my problem
  • 515 Answers
Problem might be the 33 switch. If it's gone bad, it will cause this kind of problem. The issue is not the motor. Possibly one of the capacitors or resistors might have gone bad. Not easy to determine without the proper tools and a service manual.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Posted on Aug 02, 2008
When the record plays it changes speed every few seconds from the speed it should be 33 to 45 etc...i changed the stylus thinking that may help but it did not;
What kind of record player is it? Make, model, year of manufacture, etc.? There should be a sticker or plate somewhere that tells all that info.
Apr 19, 2017 | The Audio Players & Recorders
Grundig 4400 / Audio Techinca T4P Turntable spins at 35 RPM instead of 33 RPM
I think you mean 45 rpm?
It sounds like you have got the belt in the wrong position. Try adjusting the position of the belt by experiment. Or you could look up the correct way to set up the belt.
Jul 28, 2013 | Audio Players & Recorders
Turntable spins to fast.on 33 sounds like its on 45 but on 45 its even faster
Possible that the motor is working with a different speed. It can be fault in the drive, fault in the mechanism.
What is required is the need to remove the TOP plate and look to see the drive of the motor. If there is slipping of the drive it can result in higher speed. If so it can be aligned and corrected.
Jul 12, 2011 | Philco PC-841.651 Turntable
Playback on the turntable is sped up
The first step to resolving this issue is to select the appropriate RPM speed for the record that you have in hand. If it is not a simple 33 1/3 RPM record set on 45 RPM, then it would seem that the phono motor speed could require adjustment. Your phonograph is a belt-driven PX-E860 K with a DC servo motor.
Some people mistake the the 7"/LP record size LEVER for the rotational speed BUTTON (33 RPM when raised; 45 RPM when down).
In the case of needing to actually callibrate the rotational speed, underneath the unit there is a hole labeled "33" & a hole labeled "45." Using a very fine precision screwdriver, you can callibrate the speed of each. Insert the screwdriver into the repsective hole past the rubber & slightly turn the screw (rotational speed increases as you turn the screw clockwise).
Jan 07, 2011 | Aiwa Z-L500 Shelf System
My turntable speed is too slow. I have the optimus lab 1000 and there are speed adjustments on the bottom side of the unit but turning these either for 45 or 33 rpm did not change results. I have already...
Look under the platter or on the bottom of the turntable. There should be two adjustment holes for 45 and 33. You will need a small screwdriver for adjusting these. If this does not work clean the control pots with spray cleaner.
Dec 01, 2010 | Radio Shack Audio Players & Recorders
Kenmore Elite HE3 Error FH I forgot to turn the water hoses on when I started a load. The FH error sounded at 33 minutes of a 45 minute cycle. I can't reset the machine now. It is stuck. It is unplugged....
according to kenmore, you should press the "pause/cancel" button twice and it should release it.  it may also have locked up the CCU, central control module and might need to be replaced.
Aug 02, 2010 | Kenmore Elite 45986 Front Load Washer
Deh-1700
try ebay, they have a wide variety of face plates without the radio..
Nov 05, 2009 | Car Audio & Video
GOING FROM 45 TO 33
I don't know if this model is direct driven or by belt. If it's belt driven then the belt could be fitted incorrectly, or faulty. Another possibilty is that there's a fault in the motor control circuit.
Jul 28, 2009 | Gemini PDT-6000 Turntable
My 33 & 45 speed giving problems
HELLO
I have just posted a cure for this deck, it is to do with the microswitches under the speed select buttons - they need to be replaced. Just repaired mine today - now there are no more problems selecting speeds.
If the speed goes back to 33 when the deck is switched off, this is because 33 is the default.
ALL THE BEST!
Nov 30, 2008 | Gemini PDT-6000 Turntable
Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
Nov 07, 2008 | ION Audio iTTUSB Turntable
649 people viewed this question
 Grubhead
Grubhead
