Question about Panasonic Televison & Video
My panasonic HDTV bbl 1080i was purchased about 6 or 7 years ago. The image shows two or three other images from the original image which are florence green and pink. So basically I see a triple image of the original image on my Panasonic HDTV. What is the problem? and how can fix if it can be fix?
  • dnalittle Jul 30, 2008
    Same here. I've tried DVD and Cable inputs with the same results. It was fine last night.
I have a Panasonic PT-47WX53 rear projection TV and the picture was pretty dark for the last year but for game it was OK but know the blue is out of sequence, do I need to change the lamps?
And where to find them?
Posted on Nov 21, 2010
Home cinema projector (panasonic) and blue ray player only show half an image
To me itcsounds like ypu have a 1080p signal, 1080i is what it accepts. The 1080p signal will only show up on half the screen. Switch blue ray player to 720p or 1080i output.
Jun 26, 2014 | Panasonic PT-AE900U Multimedia Projector
Install xp
To install Windows XP on a Panasonic Toughbook CF52
you have two choices:
1) Use a standard Win'XP Pro SP3 boot CD and then
then download each driver from the Panasonic Website:
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
2) Purchase the recovery disk from Panasonic directly
from the following website:
http://business.panasonic.com/support-computerstablets-dvdrequests
Here is what they say:
Recovery DVDs are available by mail for select Toughbook® products. Windows® XP back up service is only available to customers who purchased Panasonic computers with XP downgrade rights. Windows XP Backup Image and Windows 7 Recovery DVDs restore a PC to its original factory image. The standard Panasonic factory image includes the Windows operating system and all drivers/applications originally installed by Panasonic.
That is it.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Sep 17, 2013 | Panasonic Toughbook CF52 Notebook
I want to restore my panasonic cf 74 to original factory
The best way to "Factory" Restore your Panasonic
Toughbook CF74 is to use the original recovery
disk(s) that came with the unit when new.
If you can't find them, you can order them from
Panasonic at the following website:
Good Luck!
Regards,
Mar 20, 2013 | Panasonic Toughbook CF-74 (CF-74HCDAZBM)...
Panasonic Toughbook cf18 recovery disc
Panasonic Toughbook Recover Disks are
available to order at the following website:
Good Luck!
Regards,
May 24, 2012 | Panasonic Toughbook 27 Notebook
My projection tv is showing a triple image and i don't know how to fix it?
Go to menu then setup if you do not see convergence listed in menu then you have blow Fuse FL231. Located next to FBT flyback transfomer on right side there is 3 fuses in a roll they will look like small rectrangler caps but are Fuses.06 amp
Apr 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV only formats at 480i
Check in your instruction manual to see if the set can actually work in 1080i. Most of the sets going back about 4 to 6 years ago were not capable of working in 1080i.
The signal coming to your Sat box may be in 1080i, but your Sat box has to be able to output 1080i. This can be quickly verified by calling the support for your service and giving them the model number of their Sat box.
Jerry G.
Dec 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a panasonic HDTV 1080i. seeing double images
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Feb 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
1- I have a Panasonic TV (PT-53TW54)that has a "digital scan rate of 1080i,540P". I'm not sure if that means it has a digital tuner. Do I need a digital converter for this unit? 2- I'm using a...
1. Do I need any additional equipment to watch HDTV broadcasts on my HDTV-compatible TV?
In order to view over-the-air (OTA) HDTV broadcasts, you need to be within the reception area of a TV station broadcasting HDTV signals. Some TVs may require a set-top HDTV tuner and an external antenna to receive the broadcasts. Your cable or satellite provider may also offer HDTV channels as a part of their service, eliminating the need for a separate tuner. Please contact your local service provider to find out what kind of HDTV services they may offer.
2. What is CableCARD and how does it work?
HDTVs with CableCARD slots can accept a small card from your cable provider that allows you to receive standard definition and high definition digital broadcasts without a bulky set-top cable box. Please call your cable company to find out if they offer this service in your area.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif3. What is HDMI? Is it compatible with DVI?
HDMI, which stands for "High-Definition Multimedia Interface", is the consumer electronic industry's first connection capable of transmitting uncompressed digital audio/video signals. Components featuring HDMI can transmit both digital audio and video over one convenient cable, replacing the tangled mess that resides behind many home theater components. HDMI also offers improved quality over traditional analog connections thanks to all-digital transmission. Digital sources like DVDs and HDTV programming can now be transferred digitally from source to display without analog conversions that can degrade the original signal.
Unlike the HDMI interface, DVI only handles digital video. Through the use of an adapter, a DVI device can be connected to an HDMI device, but only video content can be transmitted. The audio signal would have to be transmitted through other methods such as analog RCA outputs or an optical digital output.
4. What's the difference between 720p and 1080i HDTV broadcasts? Does my CRT projection HDTV support both?
HDTV signals can be broadcast in either 720p and 1080i. It's up to the broadcaster which signal format to use, and both have their benefits. Our CRT projection HDTVs display 1080i signals in their native format. For 720p broadcasts, you can use the settings on your HDTV set-top tuner, cable box, or satellite tuner to convert a 720p signal into a 1080i signal that your TV can display.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif5. Why do I still see black bars on my widescreen TV when viewing certain widescreen DVDs and HDTV broadcasts?
Your widescreen TV has an aspect ratio of 16:9 (1.78:1), which is the aspect ratio of HDTV. However, movies are filmed at several different aspect ratios, including 2.35:1. Also referred to as "scope", 2.35:1 is a very panoramic aspect ratio that provides a wide field of view in the theater. Scope is much wider than your widescreen TV, so it still requires the use of letterboxing ("black bars") to fit the entire image on screen. Some TVs and DVD players have a zoom function that allows you to blow up the image so it fills the screen, but the sides of the image must be cropped in order to do so.
6. What will 4:3 broadcasts and DVDs look like on a widescreen TV?
There are multiple settings for adjusting the appearance of 4:3 material on Panasonic widescreen TVs. It can be viewed with black bars on the sides, preserving the way it was originally intended to be viewed. Some viewers find the black bars distracting, so they might prefer one of the stretch modes that lets you fill the entire TV screen with the image. One such mode is the JUST (justify) mode, which stretches only the outer portion of the picture while leaving the center untouched.
Oct 21, 2008 | Panasonic Televison & Video
No screen display - VIzio 50" Flat screen TV
If you purchased the TV 6 months ago, still under manufacturers warranty. They normally give customers 1 year warranty coverage.
It looks like the main board will have to be replace on this TV or fix to the component level.
Mar 21, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
PS3 can not perform 1080P.
TV will automatically convert signal to 1080i ; it's all in the tvs chip.
There's not much difference really! If your not seeing any image and show no signal in that input;you will have to reset your PS3 and it should work...hope that helps!
Oct 26, 2007 | Samsung HLR6768W 67" Rear Projection HDTV
Televison & Video Logo
204 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
