Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso washer
Hi My washer 'whines' and does not begin the cycle after filling with water. It does agitate and spin when I set it on the 'Rinse and Spin' cycle, but the time remaining never begins to count down.
Can you help?
thanks, paige
  • 246 Answers
Sorry Paige, just got back from vacation. For a whining noise, I will give you the solution that you can perform yourself without specialized tools.
Often there is a whining noise associated with pump (it turns a different direction depending on the point in the cycle. Let's check for a restricted (would still let water drain) or frozen pump.
Pull the washer forward and then tilt the top back so the washer is leaning against the wall about a 45 degree angle (when you get the right angle the washer will balance against the wall by itself without you having to hold it. Now remove the 3 5/16 screws from the front of the bottom panel. On the right hand side, follow the 2 short black hoses. They connect to your pump.
On a old style pump, there are two clips you can snap off and the pump will drop down. New style pump, there are 4 #20 torx screws that have to come out. HOWEVER, there is always water inside these hoses. Make sure you have an area that water can easily be contained, a LOT of towels, or just disconnect it and take it outside. First try taking the black drain hose on the back and lowering it from the hole in the wall into a container at ground height. This can start a siphon that will get most of the water out. This works really well if you have a wet/dry shopvac to attach to the end of it. If this doesn't work, then you will have to disconnect the black hoses at the pump to let the water out. If the pump has no debris and can move freely, then it's time for a service person. These washers use specialized tools to work on some parts ofthem.
Posted on Aug 09, 2008
Won't finish the final spin
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Post further comments for more information ....
Good Luck!!
Thanks
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washing machinge is not completing the complete cycle
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stuck in spin
Hi!
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
Do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer calypso
Unplug your machine for 5 min then turn on spin to remove water. If water won't go you have a bad water pump. Code FL refers to a low water flow problem ( won't fill fast enough ) or old water still in tub.
Next you need to turn off the water ot the unit and remove the water lines. Look into the water inlets on the washer to see if the dirt screens are clogged and not letting water into you unit at a fast enough pace.
Your unit has a water level sensor and should agitate when full, but I believe your machine might be "timing out" i.e. not filling as fast as your unit expects so even though it doesn't fill all the way it begins agitating because it has taken too long to fill. Good Luck!
barneyluc
Oct 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Calypso GVW9959K Top Load Washer Logo
166 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
