Question about Toshiba Televison & Video
MIXED SIGNALS? WILL A TELEVISION THAT RECIEVES A YCBCR SIGNAL BE ABLE TO READ THE YPDPR SIGNAL THAT THE TOSHIBA MODEL# SD-4000KU DVD PLAYER SENDS? THE TELEVISION IS A LEGEND MODEL# TQ2097L
  • 10,594 Answers
I think, titels are changed other wise both are same signals.
Posted on Jul 26, 2008
Dvd player toshiba sd-350esb schematics would be great
Toshiba SD-350ESB Manuals
www.manualslib.com > Brands > Toshiba Manuals > DVD Player
... User Manuals. View online or download Toshiba SD-350ESB Owner's Manual. ... Manuals and User Guides for Toshiba SD-350ESB. ... DVD VIDEO PLAYER.
Toshiba SD350ESB DVD player - Instructions Manuals
www.instructionsmanuals.com/modelo-8363-en-DVD+player.htm
Download instructions for TOSHIBA SD350ESB. Toshiba SD350ESB DVD PLAYER. Click on the instructions manual you would like to download for the model ...
Nov 07, 2015 | Toshiba Televison & Video
Can I connect my Toshiba dvd-player sd-770sr to a laptop and then make my laptop screen seen on my older tv that is connected with scart to the dvd player?
you can connect you dvd player to your laptop but you need a usb tuner that will accept video and audio input such as products made from razzle as i never heard of a laptop that has an input and scart has an issue connecting dvd/vcr's to tvs because of synchronizing the composite video signal (which is companded into red, green, and blue) from the VCR with the RGB signals needed by the monitor.
Hope that helps answer your problem let me know
Mar 17, 2011 | Toshiba SD770
Player will not start. it has power but the movie does not start. model number sd-p1600
This is not a TV problem? The sd-p1600 is a portable DVD player. Are you trying to connect it to your TV? Or is you Portable DVD Player not playing?
Jan 06, 2011 | Toshiba 42H81 42" Rear Projection...
Sound no picture with dvd player
Exchanged AmEx Rewards points for 3 Toshiba Model DS-4000KU DVD players in 2007. All stopped working. Two a year ago, one this week. Errors - can't read disc, bad disc, etc.
Warranty period is up. So I decided to open one up tonight since they were going in the garbage anyway.
Put on rubber gloves and took off the case. Unscrewed the player unit, lifted it carefully, and untaped lines from the botton of the unit.
Plugged the unit in and powered it on. Did not blow up! :>)
Jiggled some of the lines and connections. Put a disc in and it read it!
Attached it to the tv without putting the case back on. Received video. Yay! But no sound. Boo!
Jiggled the lines some more and tried it again. Working fine now.
Will put the case back on later and see if it still works.
Dec 09, 2009 | Toshiba SD-4000
I have a Toshiba SD-4000KU dvd player which worked fine but is now not loading and just says bad disc with a perfectly good disc what solution is there to rectify my problem. Thanks
Just wondering whether damp has affected the circuit boards.
Try putting it in a warm room plug it in and leave for 2 hours then try again.
Nov 13, 2009 | Toshiba SD-4000
I have got sound but no picture on my toshiba dvd player,model number:sd-308kb,have tried various new scart leads,all to no avail,can you help,thanks,andy.
My Toshiba sd-310v required a S-video cable and
input programming at the TV to acquire a video signal. Hope this helps.
Aug 20, 2009 | Televison & Video
YPbPr and YCbCr signal
with component, if there is not a solid signal, it'll go blue. if the dvd is dirty, the player is dirty, or any other break in signal, it'll go blue. clean your dvd and/or player.
Feb 26, 2009 | LG RD-JT30 Multimedia Projector
Dvds wont play
Check out the link I have posted below.
http://www.homemovie.com/compatibility.htm
according to the list, your in the 5% area of dvd players that won't read burned home made disks-DVD's
Sorry Pal your in the same boat as myself.
I have a Toshiba SD-2107 --- We're both aout of Luck :(
Looks like it's time to invest in a new DVD player.
Aug 05, 2008 | Toshiba SD-2109 DVD Player
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
Televison & Video Logo
55 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
