Question about Whirlpool GGQ8831L Gas Dryer
Whirpool Mod WGD5300SQ0
Had a slight flood in the basement, yeah thats where the dryer resides. After the water subsided I turned the dryer on and it worked, now it doesnt. Drum turns and blower runs but gas wont. I have bypassed the ignitor along with flame sensor and gas valve still wont open athough when I take the positive lead of the flame sensor and touch the dryer case the gas valve sounds as though it opens. ........
In my approach I have not assumed any of the fuses to be bad, and so if I have missed something significant, I would love to hear it.
BD
    Novelist:
  • 177 Answers
How much water did you have in the basement? Back in June we had flooding in the area, and the my recommendation to everyone has been to replace any appliance that was under any water.
If the motor was under water, wires or the gas valves, these components will corroded and could cause you future safety concerns.
Posted on Aug 22, 2008
Hello, my dryer got wet due to my basement flooding and it starts, but no heat.
It is highly risky to use any electric appliance even after the removal of flood water. Before using it you need to make sure that it is not wet from either inside or outside. Even a single drop of water can cause a short circuit at you home and can also lead to unfortunate event. In such case you need to search for a company like http://floodfixer.com/ that dries wet basements to ensure your safety. Professionals can bring your valuable possessions back to its original position and make them ready for reuse.
Sep 12, 2011 | Hotpoint NBXR333GGWW Gas Dryer
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
Whirpool dehumidifier mod. ad25bbl6 dehumidified the first year I baught it, but never after. It has been sitting in the basement since and I'm trying to see if it is something simple.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 04, 2011 | Dehumidifiers
Lg dryer basement flooded, water up about 8 inches on the dryer. in water about 8 hours, Dried it out turned it on panel worked drum turned but no heat then the drum stopped turning. just hums now? Is it...
there is a chance that the motor contacts have been corroded,depends on the age of the machine.and if there is a control board in the lower half of the dryer it could be as much as three hundred to fix it especially if you have a service tech come out and look at it if the unit is not under warranty.
Nov 21, 2010 | Dryers
Gas dryer. flooded basement which means water damage to some parts .about 12 in of water. when I push the start button it clicks on but turns off right away if I hold button down it spins around for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is ruined...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Whirlpool Dryers
My basement flooded with about a foot of water. Now the dryer wont turn on. Is there an internal fuse or reset? or am I looking at a new dryer?
Make sure the motor still turns (by turning the drum) Then, with the unit unplugged, check the thermal fuses and thermostats. Also, make sure you still have power to it (that the breaker didn't trip from the water.)
Mar 14, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Flooded and not heating now
There is no pilot light. You probably got water into gas jets, also all electronics to ignitor need to be dryed. Also blow out all gas parts. If dryer was plugged in at time of flood you could have shorted one of the thermal switches behind back cover. Check all of this I wrote.
Aug 17, 2009 | Hotpoint NVL333GY Gas Dryer
Whirlpool mod # WGD5300SQ0 gas dryer gets hot but does not stay hot Is it a thermostat or radiant sensor or something else
by all means when dealing with natural gas consult only trained professionals....as natural gas does not have an odor..the odor that you smell is an actually additive that has been place for just this reason.
May 03, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Whirlpool GGQ8831L Gas Dryer Logo
210 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
