posted by silvereag24 on Jul 26, 2008
I HAVE A GE MICROWAVE
MODEL#JES1136WL01
I HAVE SEARCHED THE MANUAL OVER AND OVER AND FOUND NO WAY OF REPLACING THE LIGHT BULB.
PLEASE ADVISE
THANK YOU
**** WOOD
Solution #1
posted on Aug 02, 2008
If
there's no obvious removable cover over the bulb (and the owner's
manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE JE2160 1150 Watts Microwave Oven
GE Advantium SCA2000B 950 Watts Microwave Oven
GE JE1590 1000 Watts Convection / Microwave Oven
GE JE1640 Microwave Oven
GE JE510BW Microwave Oven
GE JES1142SF 1100 Watts Microwave Oven
GE JES1288SH 950 Watts Convection / Microwave Oven
Can you Help with these Microwave Ovens problems?
GE JVM2050 1100 Watts Microwave Oven
Microwave died?
Microwave died?
Hello, Today, my microwave quit... Answer This...
GE Spacemaker (JVM1640SJ) Microwave Oven
1994 J EM27L WH 002
1994 J EM27L WH 002
Hi, My GE Spacemaker II of... Answer This...
Frigidaire FMV145K 950 Watts Microwave Oven
Buzzer Volume
Buzzer Volume
Buzzer Volume is getting more... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
Find Parts
