Question about Video Game Consoles & Games
I need to find a place to get a motherboard problem fixed.
  • 35 Answers
You would most likely have to send it in to the manufacturers and have them take a look at it
Posted on Jul 27, 2008
No 10 pin connector on mother board for usb
So you have a case with front connections and no place to hook those up? You will have to get a different case, that is a nice motherboard.
Mar 31, 2013 | Cougar Black Solution Steel ATX Mid Tower...
I have no display on my HP tx 1000
this is a common failure for those who have this tablet pc. this fail is because gpu overheating so you can't get display on your screen only black blank screen with all light indicator on.
I have the same problem and I can fix by myself with little cost. all you need is aluminum foil and oven to bake your motherboard.
1. first you have to dissemble your notebook
2. take your motherboard out.
3. take everything that stick on your motherboard i.e sticker, cables, battery, rubber (everything .. that easy to melt)
5. place aluminum on your oven surface. place your motherboard and bake it about 200 degree celcius for a 7-10 minutes.
ok I found better tutorial for how to bake your motherboard.
http://www.associatedcontent.com/article/5790852/how_to_reflow_your_laptop_motherboard.html
Oct 04, 2010 | HP Pavilion tx1000z Notebook
How to replace motherboard
1. Contact eMachines, and purchase an identical replacement motherboard.
2. Disconnect all the exterior cables from your computer (keyboard, power, mouse, et cetera).
3. Remove the side-panels.
4. Disconnect all the interior cables from your motherboard (power, data, audio, et cetera).
5. Unscrew any screws holding add-in cards (modem, video) in-place.
6. Disconnect those add-in cards from the motherboard.
7. Unscrew the mounting-screws that hold the motherboard to the case.
8. Lift out the motherboard.
9. Take the RAM out of the old motherboard.
10. Take the heat-sink-CPU-fan and CPU off the old motherboard.
11. Put the CPU and RAM onto the new motherboard.
12. Reverse the above steps, to reassemble.
Jul 17, 2010 | E-Machines eMachines Desktop PC
I have the e210882 motherboard and i have a prob with "bios" cant get in.. Need password..how can i fix this?
Hi!
It so simple, you don't need to blow your mind looking and thinking of the password. Just reset the BIOS jumper configuration straight from your motherboard and the password will be gone.
Open your computer system case and then look for this thing:
Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.
Leave the jumper in place for 20 to 30 seconds and then return it to its default location.
Its done! The password is gone!
Or you can try also this procedure.
- Just remove the BIOS battery and place it back.
Refer to your motherboard manual to do this as reference.
Have a nice day!
Thank you for reaching us.
May 20, 2010 | Dell (E210882) Motherboard
I tried to install more RAM and received 4 single
first check for the maximum configuration of your motherboard, second if that check you have fixed it correctly ,if place horizontally and then fix it , it will work
beep sound occurs only due to the above reasons
Feb 28, 2010 | MSI KT4 Ultra (MS-6590-010) Motherboard
When I open bios setup, some of the selections are dimmed and I cannot access them. How to fix it?
open yout cabiner then reset your bios setup but interchanging the jumper setting available on motherboard once u restart comp. later switch off n then place the jumper to its original place n start ur comp n try accessing bios.
Feb 17, 2010 | Intel Desktop Board D845GLAD Motherboard
No sound
You should be able to use the codecs available from Realtek with your motherboard. There are two choices - standard AC97 or AC97 HD, one of these is compatible with your board.
Post your results here, especially if this doesn't fix your problem...
Apr 03, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Fixing a Intel motherboard socket
Hi!
Its almost impossible to bent the pins back withour break them of.
99 of 100 will break for sure. and since it isent place enough you cant sold the pin back
Good luck
Nic
Mar 12, 2009 | Intel Motherboard
Video Game Consoles & Games Logo
63 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
