Question about 2wire 1800HG Router (RG1800HG00)
It is possible that my router is blocking some sites
I am having problems to connect few sites, upgrade windows,McFee,etc..still with the problem...it is possible that my 2wire 1800 gh is the responsible of not let me get normal sites like ebay,mesenger,bank sites?
  • 928 Answers
It is quite possible. You may have to access the user interface of your 2wire 1800 gh and then enable secured site access. You may have to open port 443 or lower your MTU to about 1400 or 1300. Please PM if you need further information
Posted on Jul 27, 2008
Hi, I configured my Linksys WRT 150N Router to block certain URLs. I get the sites blocked on some machines running Windows XP while I cant get the same sites blocked on some running the same XP. Its even...
I was having a similar problem, and solved it by upgrading the firmware of my router. Once I did the firmware upgrade, blocking worked fine. You can get the firmware upgrade by going to the Linksys website, clicking on Support, and then specifying your router model number.
Dec 15, 2010 | Computers & Internet
I AM NOT ABLE TO OPEN MY YAHOO MAIL FROM MY HOME PC. bUT I CAN OPEN IT FROM MY OFFICE? WHAT MIGHT BE THE PROBLEM IN MY HOME PC?
sounds like something might be wrong with your hosts file. its under Windows/system32/drivers/etc folder right click on hosts and edit. look for any entries related to yahoo and delete them. Other possibilities include security software blocking the site, safe search or parental software such as net nanny. lastly. your router could be blocking this site. try connecting directly to the internet by bypassing your router, connect your PC to your cable modem or adsl modem. Then try, this will rule out your router as the problem.
Aug 28, 2010 | Yahoo Mail
I have been using the same broswer for a long time & suddenly I could not get into Myspace.com, When trying to get into myspace.com I am told to upgrade my broswer now. How do I upgrade my broswer? ...
Hello.
If you are using Internet Explorer, here's the latest version:
http://www.microsoft.com/windows/Internet-explorer/default.aspx
If you are using Firefox, here's the latest version:
http://www.mozilla.com/en-US/firefox/upgrade.html
But, I'm a little suspicious of the message that you encountered. It could be spyware or malware. So, first download and run from Spybot (http://www.spybot.com) and Malwarebytes (http://www.malwarebytes.com)
Hope this helps.
Nov 23, 2009 | Computers & Internet
I have a Linksys WRT54g which worked beautifully for 10months. I have an ethernet connection and used it for my PC and a laptop. Now it logs on and off every couple of secs. I tried resetting the whole...
If you disconnect the router , you are able to go online. Go to the Linksys web site. www.linksys.com/download and download the Firmware of the router.
You will need to select the correct model number and the version number of the router.
The model n umber and Version number will be on the back side of the router. You will see model number in small letters like WRT54G and just after that you will see V 5 or V6 or V8. this number will be the version number.
Download the file on the computer.
connect the computer and the modem to the router again and open the router set up. Upgrade the firmware.
Click Here to know more about how to upgrade the Firmware.
Nov 18, 2009 | Linksys Wireless-G WRT54G Router
Netgear DG824m Disconnecting every few mintes
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 17, 2009 | NetGear DG824M Wireless ADSL Modem Gateway...
Router blocking websites
Do a firmware upgrade
Firmware Upgrade
1. Please verify the model and version of the router underneath it.
2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and select the model of the router.
3. Please click on the appropriate version of the router.
4. Select the link of the latest firmware. Please click on the button Right-click and Save to Download.
5. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
6. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
7. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
8. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
9. Click on Maintenance and then Router Upgrade.
10. Click Browse and locate the upgrade file in your Desktop. Click Upload.
11. Please wait for the router to reboot.
12. Reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then please plug it back in.
May 12, 2009 | NetGear WGR614 54Mbps Wireless Router...
Wi-Fi and Windows Vista Upgrade problems
Concening the wireless connection....if you dont have a router of your own then you must have been sccidently connecting to someone elses that had no security.
What exactly did you do with the upgrade disk and what disk is it?
Jan 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Power light flashing/blinking on the BEFSR41 V3
This is caused by the firmware not loading correctly. Follow the steps below to fix this. 1. You will need to gain Internet access to download the latest firmware for your router. The firmware must be present on the computer that will do the upgrade. Temporarily bypass the router and plug directly into your Internet Service Provider?s modem to gain access, or use another location other than your own to get to the Internet and download the firmware. 2. Download the latest firmware for your Router from http://www.linksys.com/download/firmware.asp. Select the model number of the Linksys router you have. Be sure to select the correct router version (BEFSR41 V3), as firmware upgrades vary by version. 3. Click the ?Get Upgrade? button. 4. After the firmware page opens, click the link that says, ?Click here to download the latest firmware...? and download the firmware file. Once you download the Zip file, unzip it and extract all files. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. Before performing the upgrade, assign your computer a static IP address. For more information, please see Answer ID 534 for instructions. If using a 10/100-network adapter, change its speed to 10Mb, half duplex. For instructions on doing so: Windows 95/98/ME 1. At the Windows desktop, click on Start then choose Settings and click on Control Panel. 2. Double click the Network icon. This will bring up the ?Network Configuration? window. 3. Locate and highlight the icon with the green logo for your network adapter and click Properties. 4. This will display the network adapter's Properties. 5. Select the Advanced tab and click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Once this has been changed, click OK to return to the Network configuration screen. 8. Click OK again and Windows will ask to restart your computer. Click ?Yes? to restart. Windows 2000/XP 1. Go to Start click on Run and type in control ncpa.cpl. 2. Double click on the Local Area Connection that controls your network card. 3. Click Properties under Local Area connection status. 4. Click the Configure button. Then, click on the Advanced Tab. 5. Click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Click OK after you made the change then click Close. Reloading the firmware 1. First, hold the reset button located on the back of the router for 30 seconds. 2. Next, to test communication between the Router and the network card: Go to Start, and select Run. Type in command and press [Enter ]. This will bring up the MS-DOS prompt window. 3. Type ping 192.168.1.1 and press [Enter ]. 4. You should get the following results: Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL= 128 5. Once you get these replies, close out of the command prompt by typing in exit and pressing [Enter ]. 6. You may now proceed to upgrade the router?s firmware with the files that were downloaded. 7. Once the upgrade is complete, the router's Power light should no longer be blinking. Note: Be sure to go back to your network card settings (from the steps above) and change the speed of the link back to ?Auto sense? or ?Auto? (the original default setting) to restore full speed to the adapter. If any of the steps do not work, or if you are having other difficulties, please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
2wire 1800HG Router (RG1800HG00) Logo
124 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
