Question about Graphics BV200 BizView 128MB (128 MB) PCI Graphic Card
Graphics Card Problem
I think something is wrong with the GPU because a lot of 3-d applications have weird stuff on the screen. I think i need a new graphics card. My mother board has 5 PCI slots and 1 AGP slot, i am not sure which one my graphics card is but i think it is PCI. I do not know what caused the problem in the first place, overheating?, and if was overheating i do not know what would be a good way to solve it.
And would getting a new graphics card solve the problem, o ya i got a NVIDIA Geforce fx 5200. I don't know if their might be something physicaly wrong with the card.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this card an AGP card?
    Master:
  • 763 Answers
Im sure that is AGP, because we have the same video card on my other computer. your PCI slot is for sound cards, link modem, etc.. whenever your playing games make sure that you put the video option in to medium or low because that starts the heat of your video card when you use it into the limit. Try to cool the video card if its happening the heat again by using a fan and aim it to the video cards.
Others are overclocking their video cards to push the capability of the video card over the limit. their using a cooling fan or a tube like to maintain the temperature of their video cards. hope that helps
CHARCOIS
Posted on Jul 26, 2008
I recently upgraded my gpu and now my screen has decided to stop working. I think it may have something to do with power supply. Just need someone to confirm this before I replace it. S
It the graphics card that you installed acceptable for that computer? What was the issue with the previous graphics card?
On the back of the computer there should be row of 4 led lights. Use the link below to determine if this is still a graphics card issue.
https://support.dell.com/support/edocs/systems/Op745/en/UG_en/trouble.htm#wp1114558
If this is still a graphics issue then you are probably correct in needing a new power supply. Be forewarned, though, that if the power supply is having problems delivering power to support your graphics card then it may have also corrupted your motherboard. :(
Dec 10, 2012 | Computers & Internet
Tip
How to choose an adequate graphic card
A graphics card is mainly composed of a processor, GPU (Graphic Processing Unit), and memory.
The graphics card is in itself a small PC dedicated to graphics applications, independent of the rest of the PC, the only link being the information passing through the port graphic and food.
Choosing a card is based on its needs and its budget:
  • For desktop applications, a map called "entry level" enough;
  • For multimedia applications, a map can read the desired video format is imperative;
  • For 3D video games (and generally all 3D applications), one more powerful is essential.
Structure of a graphics card
The essential component that will determine the performance of the graphics card is the GPU:
A modern GPU is based on different units calculation:
  • Processors Flow
  • Texturing units,
  • Raster units (ROPS).
The most important are the processors flows over the number of processors flow is important, the GPU will be more powerful (for architecture).
The model number on the card is linked to the GPU.
To enable the GPU to store its calculations, there are memory:
  • It varies in quantity:
    • 256 MB enough for the tickets range of previous generations;
    • 512 MB is sufficient for most current cards graphics;
    • 1GB is needed for cards with a very powerful GPU, the GTX 280;
    • Broadly speaking, the more you play in high resolution and filtering enabled, you need more memory.
  • It varies in type:
    • DDR2, DDR3, DDR4 or DDR5: The higher the figure, the greater the memory is fast. His type does not relate to that used for RAM PC: you can have a PC in DDR2 and DDR3 graphics card.
  • Its frequency:
    • Plus it is high, the card is more powerful.
Finally, to link GPU and memory is the memory bus.
The width of this bus is important: it may be 64, 128, 256, 384 and 512 bits: over the bus is large, most trade between the GPU and memory will be rapid. A map to 256-bit bus is efficient at a map of 128-bit bus for the same GP
on Jan 17, 2010 | Computers & Internet
I just bought my new GIGABYTE RADEON HD6850 Overclocked Edition graphics card, i connected it in my motherboard (ASUS P5N-E SLI) and it seems working, the fans and stuff, but i get a black screen. I tried...
Hi, The recommended PSU for your card is 550W.
After you connect it to your motherboard you have to connect a (6pin) PCIE power connector
to the card. Without it the video card will not display anything.
Feb 10, 2011 | Gigabyte GV-R685D5-1GD RADEON HD 6850, (1...
While playing wow my screen froze up and now there's lines on my screen....it is not overclocked...is this something that I can fix or do I need to send it back to company
STRIPED SCREEN OF DEATH
Before it freezes it starts to pixel like crazy then it freezes with a striped screen,
Possible Reasons & Fixes:
* Review your Direct X services:
  1. Click Start, then click Run.
  2. In the Open box, type dxdiag, then click OK. 3. This will run the DirectX diagnosis tool.
Failing that check whether there may be a conflict with any of your devices by clicking on your control panel and checking for any exclamation marks against devices.
* Try upgrading the RAM, which is likely to be the cause for issue if everything shows normal in Dxdiag settings. [Note: High graphics games is likely to lead to overheating GPU]
* If you are new to this issue, try System Restore.
* Try clearing the temp files/cache/history
* Power supply need to be more than 500kv, cooling fans play a pivotal role
[Overheating : CPU or the GPU]
* Change your Screen Refresh Rate
Other Suggestions:
1.Download and Install the Latest VGA Driver Update
2.DirectX 9.0c Reinstall
3. Buy a New Power Supply
4. Buy a New Fan for Your Proccesor and Check Your VGA Drive Fan Also Clean up the whole CPU
Jan 12, 2011 | BFG Technologies GeForce 8800GTS OC2...
Hi I use the Gforce 8600 gts and when ever i try to talk on ventrillio i get all these blocks all over my screen then it turns into a million little ones till i can not see anything i have to resatrt my...
Its a GPU problem.
When rendering high image resolution, this normally
happens on all application, which are VideoRam hunger.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
gnaveendra@gmail.com
May 08, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
My screen only shows color stripes when i turn it on. Is it a graphic card problem?
It can be a graphics card problem as this issue comes when there is no signal to the Monitor from the Graphics Card. Other issues might be damaged cable connecting the monitor to the CPU or when the graphics card is not properly inserted in the motherboard.
Feb 01, 2010 | XFX GeForce 6200 Graphic Card
I have a nvidia geforce 9400 Gt graphics card how can i overclock
Read this...
You're not going to get a lot out of that card, it's pretty stripped down being a 9400. Anyways, download Rivatuner then after it detects your video card it will update your registry which will allow it to manipulate your video card.
You then use it to increase your Memory and Core clocks, and also the shader clock in VERY small steps. Increase it by perhaps 20MHz then try playing the most visually demanding game that you own and play it for like 5 to 10 minutes and watch for anything out of the ordinary. When you've pushed your card too high there are obvious signs, like random pixels flashing across the screen, textures showing up wrong (colours where they shouldn't be), or your game can simply lag or crash.
Also download Speedfan and monitor your GPU temperature closely. See what it idles at normally, then use Rivatuner to increase your fan speed to somewheres around 75% and make sure that the temperatures don't pass 70C.
Overclocking voids warranties and you can damage your graphics card if you push it too hard. You have to be careful and watch for signs that it's being pushed too hard. Also, you have to make sure that you set your clock speeds back to normal when you don't need the extra power. It's easier on your card then running it at 120% or something permanently.
Rivertuner: http://www.guru3d.com/index.php?page=riv…
Speedfan: http://www.almico.com/speedfan.php
Hope it helps...Good luck
Jul 25, 2009 | Computers & Internet
Which graphics card should i use
you cannot put a graphics card in your laptop. All graphics are integrated into the motherboard already
Dec 24, 2008 | Nvidia Computers & Internet
Graphics Card
Its the AGP slot where its in most likely. IF there iw weird stuff on the screen when running 3d apps that can either be a hardware problem or a driver problem. Try updating the drivers first. Most likely the problem is not hardware yet.
Jul 26, 2008 | Nvidia Geforce FX 5200 Graphic Card
Graphics card problem
Your graphics card might be going bad. The GPU might be getting too hot. Power down the machine, open the computer case and inspect the graphics card. If your graphic card has a fan, is it covered in dust. Get some of those compressed air cans from walmart or any other store, and blow out the dust.
If you still have a warranty on the PC, don't open the case, this may void your warranty. Since you are posting here, I will assume you don't have one, so go nuts with the Air cans.
Also you might have caused too much damage, and might need to get a new graphic card, but try the air cans first.
Nov 05, 2007 | PNY Verto GeForce 6800GT, (256 MB) PCI...
Graphics BV200 BizView  128MB (128 MB) PCI Graphic Card Logo
112 people viewed this question
Top Graphics Computers & Internet Experts
David
David
Vernon Taylor
dhnguyen
Are you a Graphics Computer and Internet Expert? Answer questions, earn points and help others
