Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duets spoert f 21 error
I was wondering how to correct error ..if there are some instructions on how to clean the filter
  • cjhanson27 Jul 29, 2008
    I had the same problem. I followed the instructions of cleaning out the filter thing (and I have to say that was NASTY) but it totally fixed the problem. Be prepared for some nasty stinky water and gunk...dont know how else to put it. But it worked. Thanks so much!
3 screws on bottom front of the machice. These screws hold on the bottom cover. Once cover is removed the cleanout is apparent. Should take 10 min or less.
Posted on Jul 28, 2008
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
May 15, 2014 | Whirlpool WFW94HEAW Duet Front Load Washer
Bosch Exxcel 7 1200S Express error code f:21, unable to unlock door
Check for water still in the drum if so just clean filter and restart if no water in drum you may have to replace the door interlock
Oct 28, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Error 21 was on washer, we cleaned out drain then started washer it appeared to be working, but then error message 21 came on again. It is very late so tomorrow morning we will open drain again.
Hello, it can only be dirty filtersomething in the pump drain line blocked up or failed pump. I would check the filter again and if its clean put the drain hose in a bucket see if it drains but chances are you will need a new drain pump. hope this helps please rate my answer thanks
Jun 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is error code f 21 on a whirlpool duet sport wfw8300 3.8 cubic washer?
This means that the drain pump is clogged. Tip the machine back and remove the three screws on the bottom panel. The pump has a filter inside. Pull the filter out and clean it, it will fix the issue for sure!
Apr 13, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
F21 clogged line on a new Duet Sport less than a year old???
Hi, regarding the F21 Error on the Front End Whirlpool Duet, I was able to resolve the problem with the instructions from here, just want to stress cleaning out the filter by removing the front panel. Very easy and the error code is now gone. (screws are underneath front panel at bottom, remove stacker drawer for easy access, remove screws, pull panel off, remove the filter cap, turn to the left and pull out-that's where you will locate the clog.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer duet sport is not draining water out and displays error code f-21
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Mar 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
311 people viewed this question
Dan Webster
Dan Webster
Sal De
