Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell 1699-1 reassmble
I have taken it apart but am having a problem getting the SmartMix piston to connect to the SmartMix knob. Does anyone have any suggestions?
  • rachealdawn Jul 31, 2008
    can not get the smart mix to connect.please help, have spent 3 frustrating days trying to figure this out.tks
    Problem Solver:
  • 3 Answers
I FIGURED IT OUT!!!!YAY.
the piston comes out easily with a pair of plyers.hold the cover on your lap upside down, smart mix knob closest to you,there is a slot for the piston to fit in to, turn the knob slightly (about 1/2") you will see that you can lift the knob slightly out of the way then you can slide the piston into place. leave the knob at that position to hold the piston and slowly put the cover back in place. if the piston goes in,just before you put the cover all the way down turn the knob back to water only.if everything is in place, PUT THE SCREWS IN!!!! hope this helps.
Posted on Jul 31, 2008
  • Robert Nighswander Dec 10, 2011
    To help out with this I'd like to add... Completely remove the plunger , then flip the cover over as noted. The plunger has a tiny V-notch on it that the spiral flighting on the water mix knob will fit into and at the same time is inserted into the corner (there is an area with tabs) of the underside of the cover. There is only one corner that has tiny brackets that will actually hold the plunger in place. This assembly will work (move the plunger up and down) even as it is not put on the machine. You will know it's working correctly even before the cover (with the plunger fastened to the knob) is installed on the machine. Lastly gently turn the cover and put it back on the machine making sure the plunger is sliding into its proper place. Screw the whole thing back together and wah-la . Done! I spent many hours trying to get this thing to work before (with some help) I figured it out. Thanks for all the tips! Wish I could post some pics as it would certainly help!!!
The water doesn't come out. I've taken it apart
The reason the water is not dispersing is because the pump belt is probably stretched or worn. You can get belts and view the manual here:
Bissell 1699 ProHeat Belt and Manual
Dec 03, 2009 | Bissell 1699 ProHeat Clear View Upright...
I THINK THE SMART MIX PISTON IS INSTALLEDS WRONG
it has the rubber seal and the container releases fluid when it depressed.... bipolar lol..
fill it with hot water and prime the machine.. don't use soap just try lear the lines.. always run hot water through your machine to clear the lines before storage.. and to maintain prime
Oct 16, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1699 ProHeat Cleaner
If it is completely dead, then either a bad cord, switch, motor, or a broken connection, it will have to be taken apart to find the problem.
Aug 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699
Make sure that the piston on the bottom of the smart mix valve is in the water only position.(needs be be on the knob and not sitting in the hole). With the top off, it is easier if you have a block of wood or something under the base to hold it up. Other wise it drops down and the screws can't grap the base. Also make sure all hoses aren't being pinched.
Aug 02, 2008 | Bissell 1699 ProHeat Clear View Upright...
Same problem, smartmix won't engage
If you have had the top off, the piston goes on the bottom of the smart mix valve and should be in the water position when you reinstall the top.
Jul 31, 2008 | Bissell 1699 ProHeat Clear View Upright...
Smart Mix selector
I figured it out,since you nor Bissell was of no help. It turns out to be quite easy.
Jul 20, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat
The piston needs to be on the bottom of the smart mix valve, and the knob needs to be in the water position when you put the top cover back in place.
Jul 13, 2008 | Bissell 1699 ProHeat Clear View Upright...
Smartmix bottle
The cap and insert at the bottom of the bottle may need to be replaced, or you could have a problem with the smart mix asm. You would have to remove the top cover to get to it. Does the smart mix knob stop where it is supposed to or does it go all of the way around, if it does, then the stop on the knob is broken.
May 25, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell doesn't work with cover on...
Did you put the piston on the bottom side of the smart mix knob? If not, put it on, then turn it slightly so it won't fall off. Just before putting the top cover on, put the smart mix knob in the water only spot, then push the top on and make sure that the knob turns back and forth ok. Secure the top down, and put the flow indicator on. Sometimes when you over tighten that cap, it doesn't want to spray right. So just snug it. If you haven't pinched any lines on the base or inside the handle, it should work. Could also be that the flow indictor cap is bad. MAke sure the gasket at the bottom of the tank is on the valve and not sitting in the hole.
May 21, 2008 | Bissell 1699 ProHeat Clear View Upright...
Can't reassemble!!!
The piston is put on the bottom of the smart mix knob, turn the knob to the water only setting, then put the top housing back in place making sure that the piston went into the slot, after the top is all of the way down, turn the knob, if it turns easily, then it is in place.
Feb 10, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
422 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
