Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
My cordless mower will not start; the cable is somewhat frayed and will no longer pull up into the starter lever
    Champion:
  • 313 Answers
If ur using b&d cmm1000 type 1 to 4. unit are on recall.see service center close to you place.
Posted on Jul 27, 2008
My Rockwell mower, 6 months old and barely used, won't turn off when the throttle lever is full down. You have to push the lever near the carb hard to eventually stop it. How do I fix it?
the outer case of the throttle cable is loose under the clamp and has moved back a little
loosen of the clamp screw
put the throttle lever in the stop position and move the outer cas until the points touch
retighten the clamp
Jun 20, 2016 | Garden
I have a Snapper self-propelled lawnmower and The starter cord will not pull out to get it started. What do I do next?
Hi Patricia,
There is probably a safety lever that has to be pulled back toward the handle in order to release the flywheel. (This lever is on the top side of handle.) Once you have it firmly against the handle it should start. To stop the mower, simply release the lever. There may also be a 2nd lever to engage the self-propelled (located under the handle). It may be difficult to start with this one pulled.
Jim
May 23, 2016 | Briggs & Stratton Garden
How to start it
      Stand behind the lawn mower. Use one hand to hold the engine stop lever in the operating position. Use the other hand to hold the recoil starter handle. Slowly pull the recoil starter handle until resistance is felt, then pull quickly to start the push mower engine.
      How to Start a Lawn Mower ' Starting Snapper Mowers FAQ
      www.snapper.com/us/en/support/.../how-do-i-start-my-snapper-lawn-mowe...
    Feedback
    How to start the lawnmower - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=QsRwZZwO4oc
    May 25, 2012 - Uploaded by iScaper1
    Tips on how to start a lawnmower. I asked my wife and boys today if they could start the lawnmower. One son ...
    How to Start a Push Lawn Mower: 7 Steps (with Pictures ...
    www.wikihow.com > ... > Lawn Care
    wikiHow... there's more to it than that, especially if you want it to keep running. Of course, how to start your individual lawn mower may vary according to what brand and...
Jan 12, 2016 | Garden
Pto suddenly stopped working on my late 90's 25 hp dlt lawn tractor
Sounds like your cable might of broken. watch the deck end of the cable when you pull the lever up. If it is not moving the pully, it is broken. If you are trying to start with lever still up, even though the deck is not running, the safety switch is usually up on the lever. Try disengaging the deck lever, sit in seat, apply brake or parking brake and turn key to start. Let me know if that doesnt work and we can go from there.
Aug 06, 2014 | Craftsman Garden
Toro self paced lawn mower works just fine going forward. Cannot pull mower backwards, wheels are stuck.
Your cable might need renewing, it could be rusted or frayed where it connects to the gear lever,or the lever itself could be stuck. Try spraying it with W D 40. Check the gears inside the wheels, they might be stuck and need freeing and oiling. Stephen.
Nov 05, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 2008 suzuki400 4x4.The brake cam lever will not spring back into position.If you pull the lever the cable is tight.As soon as you pull the left brake handle the cable stays loose.How do you adjust...
The problem is more likely a sticky cable, give it a good squirt of WD40 or equivalent. Do both of them, and look for frayed wire. If you find it, then the cables need replacing
Jan 26, 2010 | 2001 Suzuki DR-Z 400 SE
I can not pull the starter cable on my petrol mower
There are a lot of answers to this. If we knew the engine make and type and model it would be easier.
Sep 28, 2009 | Garden
Craftsman mower will start with pull but not with
When it turns over, is it somewhat sluggish (not as fast as before)? I would suspect your battery is weak, and the voltage drops so low that the engine does not spin fast enough to start. Also, without knowing what type mower this is (which model) it could be the voltage drops too low to generate spark (if equipped with an ignition module)
Whereby pull starting it, you aren't loading the voltage down with the starter, and the ignition module still works... So it starts.
Charge the battery per the owners manual. If that doesn't help, you may need a new battery, or you may have a bad connection between the battery and starter solenoid (heavy cables). If a connection has high resistance, it will drop more voltage at a given current.
Jul 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Electric Lawn Mower
orange lever has to be pulled up.release the mower will stop.
Nov 08, 2007 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
155 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
