Question about Garmin GPS
Garmin c330 will not power up - Garmin GPS
  • rpressly Jul 29, 2008
    All that was required to correct the problem was to remove the cover of the C330 streetpilot using your thumbnail and pressing the "reset" button and then pressing the "on" button. Thanks for your effort, but you were rather off base with your assumptions.
  • 218 Answers
Assuming that your power source is known to be live (ignition switch on?), the first suspect is the power cord, including the fuse inside the big plug. On the tip of the plug, the silver nut should be tight but the plunger in the center should move when you press it. To check the fuse, unscrew the silver nut. Take out the fuse, which looks like a glass tube with a wire inside - the wire should be unbroken. Better yet, check the fuse with an ohmeter. At the other end of the cord, disconnect and re-seat the connections to make sure they are secure. If using the suction cup mount, you'll need to unclip the unit from the mount to do this. Another possibility is a bad battery inside the unit. My C330 kept going off and on due to a bad plug/fuse assembly. When I switched to a friction mount, it came with a new power cord and the problem went away.
Posted on Jul 26, 2008
  • Lee2fixit Jul 30, 2008
    I'm glad that you found the solution to the problem - and I'm glad there aren't any ratings lower than inappropriate!
Black Screen to no power
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Frozen screen screen is frozen and wont power off
2 OPTIONS
Feb 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Street pilot c330
It took a nap...
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Power dors not transfer thru the connection between the wire and unit on my c330 , it appears that a little gold wire has broken in the rubber mount.
It took a nap...
Feb 18, 2009 | Garmin StreetPilot C330 GPS Receiver
C330 wont turn on or power up
It took a nap...
Jan 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c 340 froze- what do I do
This solution is for c330 but it should work the same...
It took a nap...
Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin freezes
2 OPTIONS
Jun 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin auto gps c330 freezes
"Black Screen"
It took a nap...
Oct 14, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
57 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
