Question about Samsung HCJ552W 55" Rear Projection Television
Samsung HLM507WX/XAA (hdtv)
My TV is about 7 yrs old and when I try to turn it on it makes all of the sounds as if it is going to turn on, but after a minute or two it will shut down. Then the "timer, lamp and temp" lights begin to blinking.
What can/should I do?
Thanks in advance for your help!
SOURCE: samsung,model-HLP4663WX/XAA , bought in jan.
Had same problem. Bought replacement lamp. Worked for 6 weeks now I'm looking at replacing the ballast. TV turns of after 5 minutes.
Posted on Aug 24, 2008
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
  • 145 Answers
SOURCE: How do I reset my lamp timer on a panasonic HDTV
go into menu.... and you will find lamp setting. reset it to zero hours
Posted on Nov 17, 2009
  • 610 Answers
SOURCE: chnaged the color wheel and lamp. stanby/temp and
YOU MAY STILL HAVE A BAD BALLAST OR POWER SUPPLY BOARD.Samsung recommends replacing the ballast and power supply board at the same time.
Posted on Jun 04, 2010
  • 8457 Answers
SOURCE: I have a samsung HLN437W1X-XAA, DLP and have sound but no picture
Yes,the lamp require changing,life span is over.
Posted on Jun 07, 2010
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Samsung hlm507wx with ''clicking speakers''?
Color Wheel could be a problem also,Ballast Board is what turns Lamp on I would start with ballast Board and if you hear a whinning noise when set is coming on color wheel needs to be replaced then!
Encompass 1-800-638-3328 and you can find some gool deal on E-Bay i got my ballst board for 62.00 and my Lamp for 85.00 CK it out! Just typ in your model number Parts/ or Ballast boards
Sep 27, 2009 | Samsung HLM507W 50" Rear Projection HDTV
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
2 y/ old Samsung DLP TV (HLR6167) - no sound
your problem is most likely not the Tv i bet you are using an air antenna arent you
Feb 16, 2018 | Samsung HL-R6167W 61" HDTV
The t.v.just went blank while watching it.
Power boards are like time bombs. When it's time is up, it's up. Since it is 3 yrs old, I would buy a new tv. Most TV parts only last 3-5 years anyways. It did a good job.
Nov 14, 2008 | Televison & Video
Samsung LCD TV HCP4363WX/XAA Black screen no sound.
check out the link below ... sounds like a similar problem:
Aug 21, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung hlm507wx/xaa
Hi..your temp. sensor tells you when your lamp is too hot and could possible melt your engine. That is why your TV shuts down. It could be your lamp fan is not working or not working good enough to cool your lamp. You may need to replace it and very easy fix.
Mar 25, 2008 | Samsung HCJ552W 55" Rear Projection...
Samsung HCJ552W 55" Rear Projection Television Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
