Hello Patricia,
Have you checked the master brake cylinder reservoir for brake fluid loss?
I don't suspect the master cylinder as you have replaced it... but am more suspect of a leaking brake line or fitting which should have
been discovered when you had the system bled.
The only time I ever had a rear brake problem with a 2500 series Chevrolet was due to seized rear brake caliper guide pins...as your calipers are also new that is not your problem.
If your brake pedal feels spongy and travels to the floor board you have air in the system, a brake fluid leak or a failure in the power steering system, such as a broken hose, broken power steering pump drive belt, or failed pump, would result in a loss of pressure to both the hydro-boost and steering.
Find more information here:
Hydro Boost Power Assist Systems Operation Diagnosis and Repair
spongy break pedal need help to find out what the problem
replaced master brake cylinder now the brake light on dash board stays on
