Question about Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 300 - SD problem
I have inserted a new Spain/Portugal SD and it is recognised in the 'Map Info' page but neither country shows up on the 'In what country is the address' page.
If I deselect UK & Ireland in the 'Map Info' page and then select 'Where to' and 'Address', the system freezes up.
I believe your current location is somewhere in UK/Ireland, which means the Nuvi's last/current satellite fix is not anywhere within Spain/Portugal. If you need to use the maps features of that country where you're not physically there with the Nuvi, the Nuvi must be in Simulation mode first. Fold down the antenna to switch off GPS (not device) and enter Simulation mode.
Then, scroll the map screen (combinations of zooming out, browsing, and zooming in to the spot) until you find the location you want to simulate (it must be within the maps coverage). Then, tap 'Set Loc' at the bottom of the screen. At this point, as far as the Nuvi is concerned, this is the GPS location where you are at. Then you may proceed with Address Search, etc. using the other map's database.
Posted on Aug 04, 2008
Navigation map do not show up, next turn etc. Also show message "no map info".
My problem was cured by reformatting the Mini SD card that holds the map data. I had the same problem this week with my Garmin Nuvi 265. After doing an update I received the "No Data Available" message when trying to use my GPS. After trying three days of so-called fixes I remembered that, at least in my case, the map is stored on a Mini SD card. I pulled the card from my Nuvi and popped it into the computer to see what's on there. There are 4 or 5 files associated with the map. I deleted the files and reformated the Mini SD card using the FAT32 setting. I reinistalled the card into my GPS. Prior to connecting the GPS to my PC, I uploaded the latest version of Garmin Express. Once that was loaded I reconnected the GPS and had to re-register the unit. Once that was done the software told me that there was a new update. I ran the update. Lo and behold . . . after about 25 minutes the map was successfully loaded to my Nuvi and it was working as it should.
Mar 20, 2016 | Garmin nuvi 50 Travel Assistant
Nuvi 610 does not recognise sd card
According to the manual, the 610 works with SD cards, which are limited to 2GB in size. It will not work with higher-capacity SDHC cards such as the one you're trying to use.
Feb 21, 2014 | Garmin Nuvi 610 GPS Receiver
Garmin nuvi 1365 with Japanese maps I've paid and
Did you try to choose an address and type in the country?
Aug 13, 2013 | Garmin nuvi 1350 Car GPS Receiver
Change country
Do you have the map checked (enabled) on the map screen? At the main menu, press the tools icon, then the map icon and then the map info button. You should see the Europe map listed. Make sure it is checked. If it isn't, then the map will be turned off. Once it is enabled you should be able to perform searches for places in Europe
May 15, 2013 | Garmin Nuvi 205 W 205w
I want to delete maps from my Garmin Nuvi 1450 LMT to make room for different country maps. How would I do this? I have been looking for answers online and in manual for hours now with no luck. Please...
    • 1 Remove the SD card from the Garmin GPS.
    • 2 Insert SD card into your computer's card reader.
    • 3 Open the "My Computer" in either the desktop or the start button.
    • 4 Double click the SD card folder to open it.
    • 5 Hold "Ctrl" on your keyboard and left click on all the map files in the folder. Once they are all highlighted, right click and select "Copy."
    • 6 Go to your desktop, right click and select "Paste." You have created backup copies of the maps in your Garmin GPS. Return to the SD card folder via "My Computer."
    • 7 Select the map file you wish to delete, left click it once and press both "Shift" and "Delete" on your keyboard.
    • 8 Return the SD card into Garmin GPS. Turn it on. Check the screen to see if the right map has been deleted. If any mistakes are made, simply start over from step 1. Replace any map that has been accidentally deleted.
    • OR Insert one end of the USB cable into the USB port on the Garmin. Insert the other end of the cable into the USB port on the computer.
    • 2 Click on the desktop "Start" menu, and chose the "Computer" folder.
  1. 3 Right-click on the Garmin drive folder, and select "Open." Some Garmin GPS devices (e.g., Nuvi 200 through 800 series devices) will have the map files stored here. Browse this folder for maps you want to remove, right-click on the file and select "Delete." If no map files are available, go to step 4.
  • 4 Double-click to open the "Map" folder.
  • 5 Right-click on any map file that you want to remove, and select "Delete."
  • Sep 18, 2011 | Garmin Nuvi 1450LMT
    Where can I buy a map card with the United Kingdom info be bought in Canada?
    Go to www.garmin.com and if you've registered your satnav log into myGarmin.
    Click on the myMaps tab at the top of the page.
    There you will see the maps on your satnav and you'll have the option to buy new maps.
    When you're downloading the map be sure to download it to your computer and NOT your satnav. Otherwise you'll overwrite the map already on the satnav.
    When it's downloaded click the windows START button and you'll find a folder called GARMIN. Click this and you'll find an item called MAPINSTALL. Use this to install the map to an SD card which you must have inserted into your satnav. It's best to use a 2Gb SD card not an SDHC. Again be sure you do not install the map to your satnav but to the memory card. You get the option of where the map will be installed during the set up process.
    If you have not registered your satnav you can do so by going to www.garmin.com. Click on the drop-down arrow and select your country. Click on myGarmin and then on REGISTER YOUR GARMIN DEVICE. You'll be asked to create a username and password. Keep them safe as you'll need them anytime you need to update your maps or buy new ones.
    There's more information on installing maps at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps if you need more help.
    Dec 12, 2010 | Garmin nuvi 255W GPS Receiver
    Cannot find Spain on my sat nav!! It includes europe but when I go to change country to spain it wont let me and its also not included in the list of countries.
    Check out garmin website for help, its pretty good and has free downloads such as icons, themes so you can personalise your satnav. If spain is not listed try connecting the device to a pc and check and see if irt is listed in the map directory.
    http://www.garmin.com/garmin/cms/site/uk/
    Jun 15, 2010 | Garmin Nuvi 760 Car GPS Receiver
    I need help installing a map onto a gramin sat nav
    No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
    to double check follow these steps
    1. Power on the unit with the card in
    2. Press Tools
    3. Press Settings
    4. Press Map
    5. Press Info (or map info)
    This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
    Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
    Countries
    Go to the wrech symbol, tap, tap map, tap about, see the spain map. Is it checked, if not check it by tapping it.
    Dec 01, 2007 | Garmin nuvi 350 GPS Receiver
    Garmin Nuvi 660 GPS Receiver Logo
    184 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
