Question about Whirlpool ED2SHGSM Side by Side Refrigerator
Whirlpool conquest side by side Refrigerator model GS6SHAXMQ00
The door handle is loose and there appears to be no access point to tighten it. can someone out there help?
  • thedella Oct 03, 2008
    I have the same problem as well. I can't find a way to tighten it.
  • Anonymous Mar 25, 2014
    How do you get to screws that can be tightened? Freezer side handle
Me too, could anyone help?
Posted on Oct 13, 2008
I called GE. They offered to send a repairman out and waive the service charge. The repairman came out the next morning and tightened all the "screws" which are a certain type that I have never heard of. Maybe we can go to Home Depot and get this special kind of screwdriver. It is not a hex screw driver but some other type that I don't recall the name.
Posted on Oct 14, 2008
Tighten door handle on Whirlpool Conquest refrigerator
You need to remove the handle befor eyou can tighten the mounting bolt behind it. T remove the handle just grab it and yank UP quick and hard. The handle will unclip and release, then you can tighten the bolt down and re-install the handle.
How strong do you have to be?!!! Trying that and it won\'t unclip. Not sure how hard to try--or will you break something?!!
You have to pull up pretty darn hard with a jerk. That is how both handles are removed on these conquest refrigerators
Sep 01, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loose door handle thermador refrigerator
I'd appreciate thoughts on how to tighten THERMADOR not another brand refrigerator door handles. Model: KBUDT4860 A02 which is a stainless steel side by side 2 door freezer / refrigerator. Thanks.
tried the other suggestions above and damaged the surface.
Jan 16, 2013 | Thermador Refrigerators
We have a Whirlpool side by side Fridge/Freezer and the fridge side door handle is very loose and we're not sure as to how to gain access to tighten them up. Any ideas?
Try RepairClinic.com. They may have exploded views of the parts for your refrigerator. They also provide detailed step by step help making repairs. You'll need the approxomate date of manufacture, Model #, and serial #.
Feb 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Handle on fridge side is loose
Look at the top and bottom of the handle. There should be a plastic end cap you can gently pry off exposing the screws to remove and tighten the handle.
Oct 04, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool gold side by side with ice and water. The refrigerator handle has come loose at the top. The screws all appear to be in accessible as they are directly behind the door handle.
See if you can unscrew the handle at the bottom, and slide it off the top bracket. Then you should be able to tighten the top screws and re-install the handle.
Jul 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refridgerator door handle
The entire handle slides upward and out to detach from the door. There are two screws attached to the handle which can be tightened once the handle is off. Those screw heads are what reattach the handle to the door by sliding them through the door bracket opening, where they follow a short channel down leaving the handle secured again.
Dec 30, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Dec 28, 2007 | Whirlpool GS6SHAXMQ Side by Side...
Whirlpool ED2SHGSM Side by Side Refrigerator Logo
266 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
