Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Changing Belt How do I change the belt on a Bissell Carper Cleaner machine? It is the maroon powerlifter machine.
You have to unscrew the bottom of cleaner, there are instructions on bissell.com under removing a belt. Go to user guide
Posted on Aug 11, 2008
Bissell hard to push
check belt on bottom
Jan 26, 2018 | Bissell Vacuums
How to replace the belt on bissell healthy home vacumn
I think this is a terrible answer.. but after researching everywhere on how to change the belt, most answers were to look up the owners manual. So I looked it up online. this is all it has on changing the belt:
"Belt maintenance
The brush belt is designed to last the useful life of the cleaner when used according to all
instructions in the user guide under normal household conditions. If you feel that it needs to
be checked or replaced, call BISSELL Consumer Services or visit the website to locate an authorized service center. Do not attempt to disassemble the vacuum foot to change the belt."
Frustrating! Good luck!
Jun 07, 2011 | Bissell 5770 Healthy Home Bagless Upright...
Changing a drive belt
Turn the unit upside down and on each side of the roller brush is a red piece of plastic with screws remove and take off roller then you will see the belt drive stem place around stem and on roller and pop back in, Reassemble. Steve
Jun 06, 2010 | Bissell Powersteamer 1694 Upright Vacuum
Belt slipped off while in use and now it's not moving at all
The belt has probably stretched and that is why it slipped off. I would try changing the belt it should take care of the problem. You can get replacement belts here:
Bissell Replacement Belts
Oct 30, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to change the belt on a bissell powerbrush deep carpet cleaner.model 1694
Turn the machine OFF (O) and unplug from
the outlet. To check if the brush belt or
pump belt has broken, you will need a flat
head screwdriver. Insert the blade end into
the lower slot of the belt access door to
release the lower snap. If necessary, insert
the blade end into the upper slot to release
the upper snap.
Hope this helps.
Richard
Mar 10, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Nobody seems to be able to answer the question on how to change the belt on a bissell steam cleaner ..... Bissell is horrible for never giving customers proper instruction manuels .... THUMBS DOWN FOR...
i have the same prob. this is what i found
Since changing the belt is the easiest fix, we suggest you check that first. (Before attempting any repair be sure your machine is unplugged from the electrical outlet). Most Proheat models have two belts; a cogged belt that turns the brush roll, and a flat belt that turns the pump. If the pump belt is stretched or broken it needs to be replaced. The pump and belts are located in the front of the machine on the operator’s left. Turn the machine over and you’ll see a red retainer with 2 screws. Remove the retainer to gain access to the pump and belts. While you’re there check the red pump pulley, it’s where the two belts are. If that pulley is broken or loose you’ll have to replace the whole pump, the pulley is not available separate.
on your housing you will see a plastic cover adout 4 inches long remove this piece and you should see where your pump belt goes. flip your steamer over and remove the little red retainer that sits by the belt you have located. at this point you can take your brushroll out and slip the pump belt over the pump and onto your motor. then reassemble.
Jan 12, 2009 | Bissell 1699 ProHeat Clear View Upright...
Model Bissell Carpet Cleaner
I just needed the same info and found the model number - you have to turn the whole unit over. It's underneath the the vacuum unit, near the brush. Hope this helps.
Dec 22, 2007 | Bissell 8910 ProHeat Clear View Upright...
Roller and belt changing need schematics
How to change the belt on the Bissell Clearview?
Sep 02, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
267 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
