Question about Hitachi 43UWX10B 43" Rear Projection Television
HITACHI 43FDX01B Blue Vert
When looking at unit in convergance mode the blue vertical line above center is short and bent to the right - are there parts to repair this problem and in what part of the system are these parts located.
  • knap3127 Jul 26, 2008
    Thanks, I was looking at the parts area, is there a repair kit or do the parts ned to be ordered individually... I noticed a few kits out there... Are the SDK's easy to see and should I chck the part number on them before ordering?
    Again, thanks for the help....
    Thank for the help ....
  • Hitachi Master
  • 8,617 Answers
You need to replace both STK392-110 Ics and then you need two 2.2 ohm 1 watt resistors, two 1.5 ohm 1watt resistors and one 3.3 ohm 1watt, and one 1.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link with free instalation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 26, 2008
  • Sonny Berry
    Sonny Berry Jul 26, 2008
    Those are the right ICs and resistors if your model is the 43FDX01B they dont have the kit for that paticular model. They are very easy if you get the desoldering iron that there instructions specify its 14.00 at radio shack and it makes doing the repair a snap. Plus they hook you up with free online instant messageing when you do the repair in case you have any questions.
  • Sonny Berry
    youre welcome
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Lot of red streaks across screen.Try to adjust convergance, blue aligned perfect but the red didn't
possible fuse. if the red is curved or bent, if the red is straight try covering tv with blanket so the sensors get a good reading. again if the red is bent, and fuses are good..... bad convergence ic's.... local service center
Nov 24, 2009 | Hitachi 43FDX01B TV
Hitachi projection model #43fdx01b.distorted color, blue off set. Half moon line at the top, taking top part of picture.
Ur convergence is dead.U need buy a convergence kit,U know how to solder right?Buy it at these websites.Tv Repair World.com or Ebay.com.
Sep 30, 2009 | Hitachi 43FDX01B TV
Tv's picture is messed up.
Symptom: Blue convergence off, bowed inward at the top and bottom with No blue vert movement.
Cause: Replace IK05 (STK392-110) and RK54 (1.5 ohm/1W) and converge. RK50(2.2 ohm/1W)
Sep 20, 2009 | Hitachi 43FDX01B TV
Red and blue convergence wont line up. What should i do.
convergance can be tricky and you should follow a manufacturers proceedure from a manual.
most specificaly start with the green H and V Linearity and center , then the Red and Blue
Projection TV's and Component Video RGB have their Horizontal and Vertical Sync signals on the Green Component..
There may be other reasons for their specific order of operations within a calabration proceedure such as your 'RGB convergance alignment'
Jun 16, 2009 | Hitachi 43FDX01B TV
Hitachi 43FDX01B green is out of whack
The green is not adjustable in the customer menu because it is considered the 'master' color. It is adjustable in the technician mode however but if it is curved it won't even adjust properly that way either. The problem is the convergence ampifier responsible for green convergence has failed. The convergence output IC's need to be replaced.
May 27, 2009 | Hitachi 43FDX01B TV
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
Re: 43FDX01B blue convergence issues
Ditto CTF1800's comment....Check RP-41 1.5 ohm 2 watt and
other low value resistors near IC's mounted on large heatsinks.
STK392-110 original convergence IC's can be upgraded to
Hitachi # CZ 01341 new number STK394-160E for greater reliability.......Hitachi also has an IC / resistor kit # X480295,
but I don't change good resistors, only the bad one(s).
Practice good visual acuity technique and ask questions!.....T.
Jan 02, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B rear projection TV
It is adjustable only in the technician menu. You will most likely need to replace the convergence IC's in the TV. This is a very common issue. The locations are IK04 & IK05 and are generic part numbers STK392-110's.
Mar 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
