Printer will not print; item lists on the queue, but will not print.
  • ragasyam Nov 14, 2008
    yes i have the same problem plz tell me where i get the thermal head
    Problem Solver:
  • 8 Answers
The printer ribbon has been expired. Replace it with a new ribbon
Posted on Jul 26, 2008
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
Oct 14, 2014 | Canon Office Equipment & Supplies
How to clear print queue
Open control pannel and then select Devices and Printers. Then double click on the Printer icon in Device and printers pannel that is connected to your pc..A window will appear where print queue will be listed..then click select the items in print queue and the right click n choose clear/delete option.
Nov 01, 2013 | Lenovo Computers & Internet
I can't print the items in my printer queue. How do I get them to print?
It sounds like you have a print job stuck in the print que. When this happens the print jobs after the stuck one will not print either. You will need to clear the print que and reprint the jobs. Here is a link to an article showing how to purge the print que and get your printer back printing again.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Apr 14, 2013 | Lexmark X7350 All-In-One InkJet Printer
My 9500 series Lexmark won't print, computer says its not communication
1. Check your printer to be sure your printer is listed as installed
2. If the print queue is full it can become confused and just hang up so turn off the printer to empty the queue
3. Power up the printer and send one document to print as a test
4. If the printer works, you should be back in business
Jan 20, 2013 | Office Equipment & Supplies
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
I cannot uninstall my Lexmark printer model X 4580 because I have to delete print job. How do I do this on my new Macbook/Pro?
You can uninstall printer driver from library folder.
Go to system preferences and delete driver from Library /Printer .
Delete that folder then your printer driver is will uninstalled then reinstall the driver if you want to use it again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 20, 2010 | Computers & Internet
Won"t print, was using printer before
Yes, you may need to clear the print queue by restarting it and then try printing again. Its like rebooting your computer. Go to control panel>administrative tools>then Services. In Services, you'll see a list of programs, scroll down to Print Spooler then right click on it and choose restart or stop then restart. This will clear your print queue. Then try printing again. If that did not clear it and allow you to print, then let me know and we'll try another way. Pls rate this solution.
May 07, 2009 | HP Photosmart C5280 Printer
Lexmar Z611, How do I delete 20 items in printing queue?
Goto Start click on Run type in Services.Msc and hit ok.............. Now on that list select the one which says Print Spooler right click on it and click on Stop........ Now go to Run again type in Spool and Hit Ok............ on that window click on Printers....... Delete all the items under Printers............. Close that Window............. Now Right click on the Print Spooler and click on Start............. Now Uninstall the Software........... Download the Drivers from the website............Install the Downloaded drivers....... It Should work............ Thanku
Jan 12, 2009 | Lexmark X1150 All-In-One InkJet Printer
I had problem with dymo, so we printed receipt thru other printer and now got dymo fixed, so i tried to print, but it's not printing, i looked in printer que, there's some printing items that i cann't get...
right click the items in print queue and delete them. You have to wait a few secs before the print queue is clear. You can also try to reprint the same thing by right clicking the item in print queue.
Jan 02, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
jasbo
jasbo
