Question about Krups GVX2-12 Electric Burr Grinder
How to disassemble it to fix the start button, which fell into the machine
  • Anonymous Jul 29, 2008
    a dont get how to open the machine... :(
  • citizenkong Jul 30, 2008
    i have the exact same problem.
    Switch fell in machine. how do I open it?
Just adding to dhelkamp's instructions (which helped me immensely!).
The front quantity knob kan be pulled right out - it's held in place by friction only.
The side knob has 3 latches holding it in place. Releasing 2 is sufficient. Use 2 small flat screwdrivers.
As for the assembly, there are 4 latches in the inner assembly holding it in place. The location of these latches can be seen by looking at the edge of the outer shell. The front latches are just behind the holes for the rubber feet, and the rear latches are just in front of the rear holes. Use a flat screwdriver to release one of the front latches, while pressing down on the outer shell - it should give way 1-2 mm. Repeat on each of the other 3 latches, whilst keeping pressure on the outer shell. The cover should easily slide off the grinder assembly. Beware of getting pinched!
Posted on Nov 12, 2008
Given the sophistication of the German engineering behind this product I suspect that the manufacturing in China is not the problem with the switch failure due to material 'fatigue'. This is one of those pesky built in 'fail' designs that causes most consumers to simply go and purchase a replacement grinder.  The plastic tab which is an extension of the switch housing and (secured by a philips screw) fails through plastic fatigue and breaks free of the mount.  It is the most employed 'moving' part in this appliance and could have been much better designed for the consumer.  The design employed suits the stockholder's short term interest. Consumer frustration is well founded.  Conspiracy is just another word for planning!
Posted on Nov 03, 2008
  • kacke Nov 03, 2008
    My solution was to decide against simply removing the broken switch and gluing reinforcement to the tab plate using a bread bag lock and Superglue.  When that fails I will likely remove the switch,  Good luck!
Remove knob on side (carefully), pry seam on bottom edge of appliance (on underside) using small screw driver at three spots, one on each side, one in rear. Push on clear housing as you do this and entire inner assembly will slide out the bottom, allowing you to remove the black outer cover.
Posted on Sep 05, 2008
Ya know, the easy thing is to take it apart, then cut the two power cord wires from the timer/interlocks, then cut the timer/interlock wires going to the motor and just wire the motor direct to the power cords. When you plug it in, it runs, when you unplug it, it stops. Just measure your coffee instead of messing with the machine. You can still adjust the grind, which is the important part, and you have a pretty foolproof grinder (unless you are a fool!).
Posted on May 16, 2009
  • 1 more comment
  • christoweber Sep 11, 2011
    Any details needed on which to cut/which to splice?
  • dgott2 Sep 12, 2011
    well, the power cord is pretty self-explanatory (as in if a reader doesn't know which it is, they should just buy a new machine). I'll try to remember to look tonite, but as I recall, it's pretty clear which the motor wires are, since there are only two, but will double-check. I could email you a pictuer maybe.
    or maybe I could email you a "picture" instead of a pictuer. They are harder to understand in French. ha ha
Be careful when you remove the 'shell' - the sping and the plastic pin that triggers the lid safety switch may be floating around in the machine. In my case, one of the screws of that switch losened itself - all I had to do was retighten and reposition.
Thanks for your posts!
Posted on Sep 02, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I just finished fixing mine thanks to the above helpful solutions. I accidentaly broke off two of the three little latches that hold the side knob on. It seems to stay in place still. However I almost lost the little spring and white plastic cap from under the side knob. Luckily I can still enjoy the delightful click-click when adjusting the grind.
I used part of a heavy plastic laundry detergent lid to replace the broken plastic that used to hold the button ib place.
Posted on Dec 07, 2008
Thanks to wirving and dhelmkamp. Had the same situation where the starter button broke into the body. We successfully wired the power directly to the motor. Working like a charm now.
Posted on Jun 03, 2012
I was using a friend's washing machine (Hoover HNL 7126) and when I pressed the start button the whole control panel fell inside the cavity behind the buttons. How do I get it back out?
How to Replace Hoover Washing Machine Control Board
The above video might be helpful. If you are not technically inclined. A Service Technician might be a good idea. Pushing the start button should not cause this event in a properly working machine.
Mar 20, 2018 | Washing Machines
Sony ericsson mw600 blutooth swith not working and charged
Hello People!
I Fixed my MW600... :D
WHAT HAPPEND?
- I was listening music and it fell from my arm for the chair, about 30cm height and after that, it not power again...
HOW I FIXED IT?
- I had to disassembled it. I had to remove its battery, spinning a little the battery and put its back. I pushed the power button and it worked... :D
Follow this video, step by step, for disassembly the mw600.
https://www.youtube.com/watch?v=UyEC33sUS_4
Please, be careful!!!
Good Look!
Mar 03, 2012 | Sony Ericsson MW600 Stereo Bluetooth...
Jura F9-inside part fell off while pulling the tray. Cannot fix.
Kris I have this same problem. Did you figure out how to replace the flap or did you have to take it in for repair.
Does anyone else know how to replace this plastic flap?
Feb 24, 2010 | Jura Capresso Impressa F9 Espresso Machine
My start button no longer works on Whirlpool Cabrio WTW6600SW0
the plastic board where the button attaches is broken and the button fell down inside..
Feb 09, 2010 | Whirlpool Washing Machines
How do I disassemble a Brother sewing machine? I have it almost open but one part, below where you wind the bobbin, will not come apart. Part of a screw that holds a piece in place fell out while trying...
Disassemble your home sewing machine for routine maintenance Many sewing machine repairs can be made at home, and most repairs can be completely avoided through routine sewing machine maintenance. This tutorial shows you how to carefully disassemble your machine to give it a round of maintenance. You will need a screwdriver - make sure not to lose any of the screws! How to Disassemble your home sewing machine for routine maintenance
Oct 11, 2017 | Brother Sewing Machines
Need to replace my keybroad on my laptop how do I get it done from disassemble to assemble
You could refer a Guide :-
http://www.laptop-repair.info/laptop_keyboard_repair.html
If you want to Fix Buttons :-
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | Gateway CX2724 Notebook
Kenmore 13114 Start Button Fell Off After 3 months
Sears will definitely come fix that under the warranty. I was in that line of work for years, and we would come fix any problem on a machine under warranty.
Mar 14, 2009 | Dishwashers
Sharp Aquos 15 LCD TV
Maybe. Unplug the unit and disassembly it. Look for damaged parts or cracked circuit boards. You may also find the buttons you push to turn it on and activate the menu ect. may be damaged. In most cases the board can be repaired but because that would be time consuming and the repair man charges 60 bucks an hour it is usully not cost effective. You might get lucky and find a wire that fell off in the fall. Good luck.
Apr 20, 2008 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
Start button problem
You will need the new & improved select button assembly and you can order them through us if you like.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
The order form is at http://207.234.249.73/mwd/btn_form.htm
Nov 25, 2007 | Sharp R-1501 Microwave Oven
Krups GVX2-12 Electric Burr Grinder Logo
3,555 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
