Question about Saeco Easy Espresso Machine
Saeco Easy Coffee Maker
My grinder is making a funny sound and just runs continuously. No beans are ground then a red light goes on. Is the grinder broken. DO you have a service center in the Philippines?
  • 1 more comment
  • VinnieJ Aug 26, 2008
    My Saeco Easy has started really struggling when packing the grounds (should be "thwok, thwok, thwok"). More and more often, I'm getting hums instead of a resounding "thwoks", and I end up with a cup full of slightly tan water and a sludge of water and grounds instead of a tightly packed puck. Something is preventing the smooth operation of the packing mechanism, but I'm hesistant to start pulling things apart. I've removed and thoroughly cleaned the plastic grounds housing, but that's not doing the trick.
  • Anonymous Mar 24, 2014
    May i know the service center here in the phils. for saeco coffee maker?
    may i know the service center here in the phils. for coffee maker saeco...?
    Problem Solver:
  • 14 Answers
I think I solved this (I had the same problem). Upon removing the top, I found that the solenoid that moves the trap-door for the grounds was loose, and the mount where it attaches to the plastic frame was broken. Basically, the little plastic fin that should hold the lower flange of the solenoid was sheared off. That left the solenoid free to move, and made the action necessary to move the dispenser trap door impossible. Instead of doing it's thwok, thwok thwok, it would just hum.
It looked like there was no easy way to replace that part of the plastic mount, so I have epoxied and zip-tied the solenoid into place. It seemed to fix the problem.
-tony
Posted on Jan 29, 2009
Hi Tony,
I have the exact same problem. How the heck did you get in there to epoxy and zip-tie that solenoid in place? Did you need to take the machine apart? Do you have any pictures of what you did that you could send to me? Thanks!
-- Steve
rostedt@goodmis.org
Posted on Aug 17, 2009
  • goodmis Sep 10, 2009
    Thanks to Tony I discovered that my solenoid broke off its mount too. I epoxied and zip-tied it back and that seemed to fix that problem. The next problem I now have is that the grinder does not stop. Looks like the channel from the grinder to the front gets clogged easily. I've cleaned it out the best I could with a stick and even compressed air, and that worked for three cups. Now its clogged again.
    I'd take it apart, but I can't get the steam knob off, which keeps me from taking the top off.
  • 515 Answers
Have you get any water in the grinder?
If you have that you have to take out the grinder and clean it.
Posted on Jul 26, 2008
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Coffee beans out of message
HI
I hate to tell you this but your grinder is bad. The sensor in the grinder is messed up, and thinks its done grinding after 3 seconds. The grinder will have to be replaced. Sorry
Dec 16, 2009 | Saeco Incanto Sirius Fully Automatic...
Our Saeco Delux Magic coffee maker will not grind the coffee when we push the button. A light comes on that indicates that the grinder could be jammed.
Hi
The grinders run on a timer. If the grinders does not fill the doser in time you will get a light saying no beans. If this happens and there are beans in the hopper push the lever to the largest # and push the brew button again. This will clear the light and it should brew. If it is at the largest # already your beans are probably shiny and there is to much oil in the beans and this is what is clogging the grinder.
Apr 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Giro Plus Bean Grinder Section Inoperative
i am facing the same problem. Please let me know if you can fix it. Thanks.
Mar 01, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco easy
Hi Andrew,
Sorry for the delay, i´m on sick-list and have not access to computer regulary.
Make sure you not get any damp into the grinder.
Try to grind little more coarse to see if the machine will grind the beans.
Have a nice day
/Mirran
Oct 17, 2008 | Saeco Easy Espresso Machine
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco easy...
Your grinder needs cleaning- are you using oily beans and/or storing beans in refrig/freezer? Both are a problem for grinder. Also, grinder should not be set to "fine"- it will definitely cause clogging and the situation you point out.. After celaning grinder, will need to re-set it.
Jan 26, 2008 | Saeco Royal Professional Espresso Machine
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Saeco Easy Espresso Machine Logo
593 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
