Question about Dishwashers
How to reset the control unit?
Hi
I just replaced the electronic control panel on this.
It started up when I pressed the 'START" button.
It keeps washing, and wont drain, even when I push the CANCEL/DRAIN button.
Is there a sequence of buttons to press to resset the unit?
Thanks
  • Anonymous Mar 15, 2014
    after changing out the electronic control board, I need to find the reset code because the cancel and drain button does not work
    Scholar:
  • 93 Answers
Press heated Dry , Nornal, Heated dry Normal: The machine will go into diagnostic mode. this may reset your control.
If not clear the fault, unplug the power cord,open up the electronic control panel again and check your connection, maybe the wire harness to the drain relay pin is not connected correctly.
Posted on Jul 26, 2008
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
My Maytag MTB2156DEB fridge died. Electricity is on, lights are on but nobody home, I.E., no cooling. my old fridge had a "reset" button which I found out after the repairman charged a bundle to press. ...
Your model doesn't have a reset button, this is non-electronic. First, tap on control panel to see if cold control is stuck. (tap on beat) If it starts it could be a bad control. Does to compressor click like it wants to start? Lastly, there is a defrost timer within the control housing, with a screwdriver rotate the timer slowly to see if the timer is stuck. If the unit starts running it could be that the timer needs to be replaced. Get back to me and I can help further if needed. Good Luck
Mar 07, 2015 | Maytag Refrigerators
Bizhub c 450 error c 3752
Fuser Heat Error. Sometimes this code can be cleared by using the reset procedure outlined below. If the code returns then you will need to have the unit serviced.
Reset Procedure: 1. Turn main power switch OFF.
2. Turn main power switch ON while pressing the Menu/Select key.
3. Keep pressing the Menu/Select key until the LED turns OFF on the control Panel.
4. Check to make sure that "Trouble Reset" is displayed on the control Panel
after LED turns OFF.
5. Pressing the Menu/Select key.
6. Check to make sure that "OK" is displayed and the it has been reset.
7. Turn main power switch OFF and ON again, and make sure that the machine properly
starts.
Apr 08, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
F1 flashes half way through the wash
Hi...
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this IMAGE...
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Oct 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My duet keeps flashing F1,what dose that...
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating AND POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Oct 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool washing machine duet and i keep getting a code f1
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When I try to start machine to wash, it keeps blinking F- O1
Sep 11, 2010 | Kenmore Elite 45986 Front Load Washer
WATER SHUTS OFF WHEN STARTED 3 TIMES
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$@#$
Apr 01, 2010 | Kenmore Elite 45986 Front Load Washer
Washer won't start
Feb 11, 2010 | Kenmore Elite 45986 Front Load Washer
What does it mean when it says scanner failure?
Hello it means that the scanner bulb temperature is too low or there is some internal or external electrical malfunction.Try these solutions.
1.Check the scanner light.Make a color copy of any document by pressing the Start, Copy, Color button on the product control panel.While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
2.Make sure that the room temperature is suitable for your device
3.Perform a Power Cycle on the unit by following the steps below:
1.Turn the unit off.
2.Unplug the power cord from the unit.
3.Wait 30 seconds, and then re-connect the power cord to the unit.
4.Turn the unit on.
5.Make a color copy by pressing the Start Copy Color button on the control panel.
4.Check the power connections.Disconnect the power cord from any power strips or surge suppressors and then plug it directly into a wall outlet.Try making a color copy by pressing the Start Copy Color button on the product control panel.If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
5.Perform a partial reset
1.Disconnect the power cord from the product.
2.Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
3.Try making a color copy by pressing the Start Copy Color button on the product control panel.
6.Perform a semi-full reset(Performing a semi-full reset deletes any saved phone numbers on the product).
2.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
If nothing of these works and you still see the error you should take your printer to support service for repairing the parts.
Feb 08, 2010 | HP OfficeJet d145 InkJet Printer
Dishwashers Logo
359 people viewed this question
Top Dishwashers Experts
