Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Set up cd
The setup cd does not load
  • sudhirshams Nov 28, 2008
    same problem.. but in my case..setup starts but after 20% completion..it says that installation failed.. without any message...
    please help
  • 928 Answers
I would assume in this case that you are using Windows Vista.
this is because the CD will not load for Vista as all you need are the drivers off of the CD and the adapter plugged in
1. Put the CD in the drive.
2. Go to start search then type in device manager
3. Select it from the list.
4. Look for an exclamation point on one that would say network adapter. If the network adapter shows up click on the plus sign and if you see linksys there then it has been installed.
To use the adapter.
1. Go to control panel
2. Go to network and internet.
3. Go to network and sharing center
4. Go to manager wireless networks on the left side.
5. Click on add then add a network
6. Select your network from the list and connect.
7. If it asks for the network key that is your networks wireless password.
Posted on Jul 27, 2008
I want setup windows xp my ibm thinkpad t23 i can pot cd & restart press f12 but not start setup plz halp me haw can i setup windows xp my ibm thinkpad t23
If your trying to reinstall a new copy of Windows in your computer then first thing you need to do is change the Boot sequence of your computer so it will load the Windows CD you inserted then it will run the set up.
To change Boot sequence:
1. Go to BIOS - Press F1 or F2 (depends on model of your computer) immediately after you turn you computer on
2. Go to Boot Menu on the top of the window
3. Change your Boot priority - make sure your dvd drive is your first or primary boot.
4. Press F10 to save and exit.
Make sure you have your Windows CD inserted before pressing F10 coz your computer will restart and will loadautomatically load and run the Windows Setup
Note: If a message "Press any key to boot from CD" appear on a black screen press any key to start the set up
Your Feedback is greatly appreacited.
Hope this information will be helpful. Thank you for using FIXYA.
Apr 21, 2011 | Computers & Internet
Sir i have dell vostro 1014 laptop.. I want to format my laptop.. I try it but the c folder is not format the O.S was install in D folder.. But i want to format my c folder and boot the system on c folder...
Hi
The operating system installer CD your is damage. Just get other copy of operating system and it sure will work. I happens to me like that the when you load the operating system installer CD it does not load or when loading the set up, some files are missing or cannot be copy because of the CD lens problem. Too many scatches or not good copy of operating system.
regards
Mar 23, 2011 | Dell Vostro 1014 Laptop Computer
How do i reformat my pc
Hi Good day!! Sir/Madam if you want to format your pc you will need and CD of a Operating system like WindowsXp/Vista/etc.(note you should have the product key after installing the OS)
here are the steps on reformating:
1. Open your Bios setup by Pressing del or f2 it depends on your board.
2. insert your bootable CD on your CD/DVD rom.
3. go to boot setup, set your boot priority 1st boot must be your CD/DVD rom, 2nd boot your harddisk after you set your boot priority press f10 and then save changes. it will restart your pc.
4. your computer will boot in CD and a message will appear "Press any key to boot from CD...." you should follow it. press any key!! if you boot from cd successfully you should be on windows setup it is a blue screen!! congrats!!
5. windows setup will load it's driver, when finish loading there will be a option on the bottom.
6. press f8 for terms and agreement (read carefully)
you can start formating just read the instruction.
REGARDS
JR
Oct 14, 2010 | Computers & Internet
Dell Inspiron 530s/531s desktop, Win. Xp home...Windows stops responding at the ''Loading Personal Settings'' cannot boot in safe mode.
try to boot in "Last good known configuration settings" by restarting your pc and then press F8 before windows appear and then select the boot option i mention above. if this not work since you said that it can't boot to safe mode, your other option is to repair the windows or else reformat it. when you repair the windows you must have windows xp home edition cd installer, you load it to your cd/dvd rom and then restart your pc and press F2 or DEL button before windows appear in order to go to setup bios settings. in bios settings, you choose boot order setup and setup first priority to cd/dvd and press F10 by saving the changes and then press any key when you see the prompt so that it can boot up to windows xp home cd installer and then follow screen instruction that you arrive to windows repair option.
Mar 27, 2010 | Dell Inspiron 530 Desktop Computer
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
Mar 02, 2010 | Computers & Internet
I can't load win xp
check the hard disk option in bios or load bios setup default then check
Aug 25, 2009 | Asrock P4I45GV R5 Motherboard
The following message appears BOOTMGR is compressed press Ctrl+Alt+Del to restart doing this produces the Advent Screen with the following options Press Delete key to run Setup Press F11 key to run Boot...
Delete key takes you into the BIOS Setting Setup that should be avoided if not sure of what it is all about, THOUGH it would be Ok to choose Load Default (Safe) Settings and then save and Exit (F10)? and Y or something like that.
F11 is a shortcut to a setting within BIOS Setup, it lets you choose Boot Device from List, normally you would try the Hard drive , as it is there that you want Windows to Load from unless of course you are trying to boot from a Windows CD/DVD then you would choose the CD or DVD from List....good luck
Apr 09, 2009 | Advent 4211c Notebook
Just purchased IBM Intelistation 6221..installing windows????
hi! try this. reboot your cpu, then press the CMOS setup key (del), then select load default setting, then go to hard disk detection settings, select the LBA setup. I believe you know how to manipulate the CMOS setup configuration. if still doesn't work out, bring it to the service center near you and ask for assistance, Im sure they would love to help you. Have a nice day!
Dec 20, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
INSTALLING PICTUREPROJECT
Most all software can be installed from the cd and by running the setup program in the correct folder on the cd. If the cd/dvd is set to autoplay, then the setup program will load after inserting the cd in the cd/dvd drive.
You may not necessarially have to have the camera plugged in to install the program/s.
May 26, 2008 | Nikon COOLPIX L3 Digital Camera
Restoring factory setting
You can reinstall the system disk if it came with one. If not, Acer can provide you with one. If it is under warranty they will do it at no charge.
It is a good idea to back do a up before reinstalling -- just in case there is a problem.
Mar 09, 2008 | Computers & Internet
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
371 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
