GE 27831 Cordless Phone Logo
Posted on Feb 19, 2011
What battery does GE model TC27831FE2-B take?
Trying to find model number on my GE universal remote so that I can get codes for my converter box
Locating the model number on a GE universal remote can vary depending on the specific model. Here are some general tips to help you find the model number:
  1. Check the Battery Compartment:
    • Open the battery compartment on the back of the remote.
    • Look for a sticker or label inside the compartment that may contain the model number.
  2. On the Remote's Front or Back:
    • Check the front and back of the remote for any labels or markings that might indicate the model number.
  3. User Manual or Packaging:
    • If you have the user manual or the original packaging, check there. The model number is often mentioned on these documents.
  4. Behind the Battery Cover:
    • Remove the battery cover and inspect the area behind it for any labels or markings that include the model number.
  5. On the Remote's Body:
    • Inspect the body of the remote itself. Some models may have the model number printed on the front or sides.
Once you locate the model number, you can then proceed to find the correct codes for your converter box. The codes are usually included in the remote's manual or can be found on the manufacturer's website. If you are unable to find the model number or the manual, you may need to contact GE customer support for assistance.
If you provide more details about your GE universal remote, I might be able to offer more specific guidance.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
Battery for GE MAC1200ST
Here is its part number 303 44270, 18V 1.4Ah nickel cadmium Battery ,
I NEED Thomson battery Model No:KLB55N80
Here is a link to a site that sells batteries, I used it for my Panasonic cordless. Your GE 25839GE3 model number phone is listed. http://www.emtcompany.com/ge-2-5839ge3-battery-3-6v-600-mah/pcf03.html
GE Model No. 2-9320B land line phone says it takes a lithium battery but when I take cover off there is no place for a battery?
marcolowenst: I also have the GE Model No. 2-9320B and when you take off the little door for the lithium battery, you should see what looks like a black bar gently pry up the little black bar (battery holder) and lift it out, there should be a round lithium battery there.
Battery to get for GE model no-25951EE2-A???
you should be able to find the battery at radio shack
I HAVE A GE SPEAKER PHONE #29870 AND IT SAYS TO CHANGE THE BATTERY, TAKE THE BATTERY COMPARTMENT DOOR OFF AFTER REMOVING THE SCREWS. I FIND NO SUCH DOOR!!! ALSO IT DOES NOT SAY HOW TO TURN ON THE SPEAKER!!...
http://www.home-electronics.net/ge/pc/user-manuals.asp
I was looking for your model number on the GE website listed above - I found the "69" model and the "71" model. There may be more letters and numbers after the model number you gave
Example 29870GE3
Need phone to store area code - tc27831fe2-b
Delete the area code. It's in the instructions.
2answers
GE portable phone 2 handsets TC27831FE2-B
SWITCH THE PHONES TO THE OTHER BASES.... WORKED FOR ME.
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
