The agitator in my G.E. washing machine is loose.
  • 3,037 Answers
Hello
Some are secured with a screw that holds them down to the shaft, some have ring clips and some are made with tightly fitting spline. If there is a cap on the top of the agitator you can pop it off to see if it has a screw or ring clip that has come loose
Posted on Jul 26, 2008
    Genius:
  • 1,847 Answers
Remove the agitator and put it back using this link.....
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
4 Suggested Answers
  • 1314 Answers
SOURCE: WPSF5170W0WW G.E. Profile Performance Washing Machine
most ge washers you just get ya fingers under the bottom and jerk up hard they have a plastic piece under them that has to be replaced from time to time its no big deal
Posted on Jan 18, 2008
jsrock516
  • 5911 Answers
SOURCE: loose agitator
Remove the center dispenser. Under the dispenser is a plastic cap with a pull handle on it. Pull the cap straight up and you will find a mounting bolt underneath. Using a socket and ratchet, tighten the bolt snug. DO NOT overtighten as this may cause damage to the agitator. If you go to searspartsdirect.com and type in your model number, there is an excellent exploded view diagram of the agitator components under the "Agitator, Basket and Tub" heading. If you still require assistance, please let me know. I hope you find this information helpful.
Posted on Sep 24, 2008
jsrock516
  • 5911 Answers
SOURCE: need to tighten loose agitator on whirlpool
You need to pop the cap off the center post of the agitator, followed by removing the plastic cap and o-ring inside. The agititator bolt is located underneath. Tighten with (I believe) a 9/16 socket with ratchet. Tighten until snug. Do not overtighten as this can restrict agitator motion and may crack it.
Now, if you talking about the upper portion (auger) of the agitator slipping, you will need to replace the agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The dogs are small plastic teeth that are located under the center post cap used to grip the auger as it turns. They do wear out periodically and require replacement. If you go to appliancepartspros.com and type in you model number you can view them as item number 10 under the "Agitator, Basket & Tub" section. You can use the part number I provided in the link, or use the Whirpool part number on the website. Both numbers cross reference to the same part. A very inexpensive fix...
If you still need assistance, please let me know. I hope you find this information helpful.
Posted on May 14, 2009
Agitator snappedin two at bottom? What would cause that? Is it possible to just re place the agitator?
agitator nut came loose
agitator plastic aged ..brittle
clothes got under and snap
a universal fit agitator
a used agitator from a washing machine mechanics stock of used parts
ebay ?
or if machine is not too old from the maker of the machine
Oct 30, 2016 | Washing Machines
LOOSE AGITATOR AND TUB
The tub hangs on 4 suspension rods the agitator is pressed on to the agitator couping. It should not be loose
Jan 12, 2014 | GE Profile Prodigy WPSE4200A
My Whirlpool LSR8233EQ0 washing machine making loud whining and banging noises during spin cycle only...any ideas on what to replace?
Two possibilites would be a loose agitator (some agitators can betightened from the top, check for tightness)If you can't tighten the agitator from the top, turn the machine over ( you will probably need to disconect water hoses first) and check the underside. From here you should be able to determine if the agitator is loose or more likely you've got a loose drive belt.
Nov 16, 2011 | Whirlpool Washing Machines
My Roper washing machine model RAL 5144 AW makes noise when it agitates - like something is loose.
Sounds like your agitator needs to have the agitator dogs replaced.If you take off the top of your agitator you can look down inside and see what's happening. Hope you find this helpful.
Jun 23, 2011 | Washing Machines
The agitator seems loose on my Maytag top loading machine.. model LAT9206BAE it started this after one of my kids overloaded the machine.. works fine but makes a loud clanging noise while washing.. almost...
Use a 1/4 inch nut driver to tighten the set screw to the agitator shaft. It is about 3 inches up from the bottom of the agitator on the side of the agitator.
Dec 28, 2010 | Maytag Washing Machines
Washing machine agitator is loose and makes a lot of noise. Can't figure out how to remove the agitator
Remove top cap of agitator (it may need to be gently pryed up or simply popped off). Under the cap is a large nut which needs to be removed. With the nut removed simply pull the agitator up.
Feb 19, 2010 | Whirlpool OEM FSP Washing Machine Pump
Agitator loose
lift out the softener cup located on top of the agitator,there is a 7/16" nut bolted down into the agitator spline that may have come loose
Jan 16, 2010 | Washing Machines
Cannot get agitator off shaft Hoover 550M washing machine
Had to cut agitator away leaving metal boss exposed will now use a puller to pull off drive shaft
Dec 22, 2009 | Washing Machines
Washing machine won't agitate.
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Nov 01, 2008 | Washing Machines
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
