Question about Zanussi ZCE7551X Electric Kitchen Range
No heat Hi all,everything works fine,apart from main oven has no heat,what spare part do I need to repair.regards
  • 2,692 Answers
Disconnect the element in the oven and test it first preferably with an OHM meter. Should have a fairly high resistance. If no meter movement it is open and of course needs to be replaced. If total meter (moves the same amount as if you had the two test leads together) it is shorted and need to be replaced. If it has a large resistance it isa likely onk and you will have to look at the oven control or wiring next..
Posted on Jan 03, 2009
My kitchenaid microwave will not heat in microwave mode. In fact the turntable starts and stops and the display blinks intermittenly. In convection oven mode everything works fine - It heats, turntabl
The magnetron is the main part that gives out microwaves to heat the food. As the convection bit is working this points towards the microwave bits.
The magnetron has a main diode, fuse and transformer to run the microwave bit, any of these could be faulty. A word of warning though, there are extremely high voltages inside microwaves, even when unplugged in the main capacitor. Also to repair this section you will need to be a fully qualified engineer to even order parts for this.
Find a microwave technician who can repair for you
Nov 04, 2014 | Microwave Ovens
I have a Bush AE56DA electric oven, the main oven has stopped heating up. Also the oven light and thermostat light have stopped working. Everything else works fine. Any idea's? Thanks.
This sounds like a regulator problem, now there are the switch or a built in behind the cooker. WARNING DO NOT OPEN ANY PART OF THE OVEN ISOLATE THE MAINS FIRST.
You will need a tester, multi-meter would do. check the switch for continuity check the heating element there may be a hole in it, its very difficult to see slight Gray Colour just at the hole, find and inspect the fan motor if there is no continuity after disconnection of wiring between the winding terminals, on most models you have to remove the fan before you can inspect the heating element, but there are a few the other way round. Hope this is helpful .
Nov 02, 2014 | Ovens
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Aug 08, 2011 | Microwave Ovens
My whirlpool mh 1140 xm microwave/ hood combo is not heating. everything else works fine, just the heat. I would rather repair than replace. Help!!
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Mar 08, 2011 | Whirlpool MH1140XM Microwave Oven
Maytag Gasline Oven - everything works fine - range and brolier start immediately yet oven clicks but does not heat anymore. Was working fine but no longer heats.
Oven not Working or
Oven not Heating
Jan 18, 2011 | Maytag CWG3100A Gas Single Oven
MH1160 Whirlpool Microwave Stopped Heating
Are you getting 110VAC on the primary leads of the high voltage transformer when you press "Start" to begin cooking?
If not, yhen it may simply be a bad cook relay (I do board repair) or a bad bottom or inside top door switch. See
E-mail me via my site for more free help.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 21, 2017 | Whirlpool MH1160XSS Stainless Steel 950...
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Ge microwave won't heat everything else works fine
Hello t_sumner4756,
Everything else can work perfectly fine but if it doesn't generate microwaves to heat your food than it is not working ( you knew that anyway).. Unfortunately, and in most cases when you microwave stops working in that manner..the components at fault are either the Magnetron, Filament PS or a High Voltage Capacitor..What that means is that you are probably better off just replacing the entire appliance rather than attempting to repair it. If it is a year old or less, bring it back to where you purchased it and have them replace it.. I am sure that is not what you wanted to hear but when the cost to repair exceeds the cost to replace... it just isn't worth repairing.. Plus.. there is an element of danger associated with these kinds of repairs...
Nov 22, 2008 | Sharp R-303CW Convection / Microwave Oven
MagiCook 22C not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Nov 14, 2008 | Whirlpool GH7155XHS Microwave Oven
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
Dec 19, 2007 | Tecnik TKC1285 Dual Fuel (Electric and...
Zanussi ZCE7551X Electric Kitchen Range Logo
395 people viewed this question
Top Zanussi Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
