Question about Compaq (253219-002) Motherboard
Compaq v2000 my laptop turns on starts to load gets to the windows screen and turns off . will go longer in safe mode but will still shut down
  • 781 Answers
First try your original O/S disk to reload windows when it loads all drivers etc it will ask you what you want to do. find out what key is for repair (usually R) press it and follow instructions from there
Posted on Jul 26, 2008
Cant log into windows. screen black
If you have a function button try holding it down and pressing F2, possibly the screen has been accidentally switched off.
Apr 15, 2013 | HP Compaq Presario V2000 Notebook
Will Not Boot/Keeps Rebooting
suspected hard disk faulty or OS corrupted.
to check, take out your hard disk and put it in other laptop. if the problem persist your OS is corrupted. In that case, you need to reformat your OS in a defaulty factory settings.
May 22, 2009 | Compaq Presario R3000 Notebook
I have a compaq prsario v2000 laptop that won't get past the windows start up screen.
Try booting the computer in SAFE MODE and if that works click on a few program to see if running OK the reboot
Jan 22, 2009 | HP Compaq Presario V2000 Notebook
Screen goes blank after windows loads
Hi there
If you tried in safe mode and still no joy you will have to perform a system recovery with the recovery disk you got with the laptop or the recovery partition, Please be aware that you will loose data.
Good luck
Jan 19, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 boot problem
Bios is not on an hard drive, is on a memory chipinside computer. Your main problem is not with Bios, but with system.
On many Compaq you can start the recovery tool by pressing f10 or f11 on startup. The system recovery tool it is located on hard disk, if it does not start it had been deleted or is damaged.
In your case Windows is corrupted, that is the reason why it is freezing , and then giving the blue error screen.
You need to get a Windows setup disk and reintall Windows. If you install windows from a generic setup disk you will need to install drivers after installing.
Drivers can be downloaded from HP website.
Another solution is calling the phone number listed on the user manual to contact HP. you can buy from them an original recovery CD, in this case you won't need drivers.
Otherwise you can ask a quote to a local repair shop for a system reinstall, I think it is about $80.
Sep 02, 2008 | HP Compaq Presario V2000 Notebook
Laptop compaq v2000
This is called the Blue Screen of Death (BSoD), as scary as the name sounds if your laptop isn't ancient you more than likely can save it. depending what you were doing on your pc last, installing a game or whatever, start it in 'safe mode'. it should start up just like a normal computer but with a few changes like anti virus disabled. From here you can unistall whatever you were last doing on the computer, clean it up and try get her running again, the usual stuff, try defrag the computer, right click the drive in my computer>tools>defrag now, theres also other options in there like clean up and error checking both will help. Try and save it yourself, if all this fails your computer fixing person will probly have to wipe your hard drive, in which you will loose all your data and start a fresh laptop.
It would also help to know what you last did on it, on the net? downloading stuff? installing something?
Aug 17, 2008 | HP Compaq Presario V2000 Notebook
Laptop compaq v2000
your windows install is screwed up. i'd dig up your Windows XP CDand pop that in and do a repair install. if it still doesnt work then i'd enter the bios setup (hit F10 on compaq boot screen) and look in there for "Hard Drive Test" and run that. be aware it will take 70 mins on a 60GB hard drive, and longer for a bigger drive. if the hard drive passes the test then you may want to boot up the XP cd and do a fresh install, opting to format the drive. be aware that formatting WILL delete anything and everything on the laptop.
if the hard drive fails the test, then obviously you need to get a replacement drive and reinstall Windows on that. if the hard drive failed, any data on it is most defenetly toast.
Aug 16, 2008 | HP Compaq Presario V2000 Notebook
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
Windows XP fails to load and Computer will not start up.
Boot from startup floppy disks or CD-ROM, choose repair option during setup, and run Recovery Console. When you are logged on, you can run FIXMBR command to fix master boot record. This should solve your problem.
Sep 20, 2007 | HP Compaq Presario V2000 Notebook
Compaq (253219-002) Motherboard Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
