Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Shadowing Replaced the light engine on my HI 50v550 about 10 months ago and now am noticing a shadow around most images -- espacialy a dark on light background. Is there a service menu fix to this ???
  • docbarnes Aug 01, 2008
    Notice alot more on HD but seems the image is shadowed on the left side of the image on screen.  Example:  golf flag-seems that image is shadowed to the left of the flag.
  • 927 Answers
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
Shadowing - 03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Posted on Aug 12, 2008
Model # 50C10 50' Hitachi projection HDTV
in da background yes a white shadow and patches of dark but the picture looks good just the white shadow. Ok when I first turn the tv on then couple of mins the shadow appears
Posted on Sep 08, 2011
Hi i have a Philips 4331 LCD projector its giving me double image which is not well colour mixed i have tryed to clean all the LCD pannel and all the lance but problem is still the same, if you have any...
If you are having "shadowing", this indicates a convergence problem in the LCD optical engine. Convergence is the correct alignment of all panels so there is no shadowing, or at worst limited to a one pixel shift. Some models can be adjusted, others cannot depending on the optical engine.
Aug 14, 2010 | Philips cBright XG1 Multimedia Projector
I have a new bulb but am getting a dark shadow around the edges of the picture. The bulb seems fine, but the shadowing is covering about half the screen. Any ideas?
The light tunnel under the colorwheel has collasped. This is a major repair. I have known some to glue the tunnel back together, but it requires patience and skill and the right kind of glue....
Jul 10, 2010 | InFocus IN24 Multimedia Projector
Shadowing on lower right of screen on InFocus LP70+
the light tunnel (like a square tube of mirrors) is collapsing. it needs to be replaced, but it's a bit involved, so and infocus service center would be your best bet. if you wish to try it yourself, let me know.
Jul 14, 2009 | InFocus LP70+ Multimedia Projector
MINOLTA QMS magicolor 3100 printer, repeat shadowing
Рthe rechagin corona in imije unit is demeged change it
Mar 12, 2009 | Office Equipment & Supplies
Samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
Feb 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Shadowing on screen
You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
bimmerhp
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Green Shadowing Around Images On Akai PT4398HD
your convergence amp's are defective this can usually be repaired for a few bills. easy fix for a qualified repair person...john
Aug 31, 2007 | Akai PT4298HD Rear Projection Television
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
644 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
