Question about Nvidia GeForce FX 5200 Video Card Graphic
Loss of output from graphics fx5200 card.
Hello all
An old system. Asrock K7VT2 motherboard with 384meg of SDR ram, running XP Home.
I bought a couple of 512MB strips of DDR memory as per motherboard manual spec. Took out the existing RAM and inserted one new strip. On reeboot, the monitor displays 'no signal input' message. Tried it in both RAM sockets with the same result.
I'm reluctant to try the other strip.
If I reinsert the old SDR strips, all seems well, albeit a bit slow!
Any advice would be appreciated.
  • deejay2 Jul 28, 2008
    Thanks colliewob.
    The problem is now solved.
    I updated the graphics card driver.
  • 781 Answers
Did you try 1 new ram at a time.also did you check the ram settings in the BIOS
get the numbers off of the new ram and do a search for them on the net they may not be not correct for your computer
Posted on Jul 28, 2008
No VGA output
Hello the drivers site is here:
The manual:
I think you should drop the onboard graphic and install a better graphic card in the 1 x PCI Express x16 slot on the mainboard.
Check the power supply for any fault.Is it new ???
You can not use the old Power supply because it might have a 20 pin connector this asrock has a 24 pin connector.
Check also you not have used the extenal graphic power connector in the 4 pin 12 + volt on the mainboard.
Check also all your power connections.
Reply me again if you can`t find the fault.
Good luck
Nov 28, 2012 | Asrock G41MVS3 Motherboard
Hello, I want to know, if the motherboard Asrock K7VT2 can support DDR2 memory.
No, it supports DDR, SDRAM...front side bus speed 266/200 can max out with 2GB's of PC3200...1GB in each slot. I hope this helps.
Aug 06, 2011 | Asrock K7VT2 Motherboard
I hear 1 beeps then 8 then 2
May 11, 2011 | Asrock K7VT2 Motherboard
Just bought and installed AsRock K7VT2 and CPU Athlon XP 2200plus XP Pro SP3 512 MBytes Synchronous DRAM GeForce 2 /MX400 AGP x4 The computor starts but i can't get into BIOS only got a black...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 05, 2011 | Asrock K7VT2 Motherboard
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
I would like advice on upgrading my Graphics card
Unfortunatly your still running low end CPU power and low end agp graphics. Your going to pay 150-200 just for a fair PCIe/AGP HD/3D VC. If $200 doesnt hurt (and this is the lowest price best option), then might I suggest Mobo/CPU/RAM for around $200 that would do the trick and allow for future upgrades. You might also need a power supply. I just built one less than 3 weeks ago for a friend and it fairs against my own gaming comp.
MY PC...
AMD ATHLON 64 X2 DCP 6000+ 3.01GHz
XFX 8800GT AD 512MB
500W PS
NEW PC....
Gigabyte GA-MA785GMT-UD2 MB $90+/-
AMD Athlon™ II X2 250 BOX 3.0GHz (CAME W/FAN)$70+/-
Sep 12, 2009 | Asrock K7VT2 Motherboard
RAM vs BIG 7200GS Graphics card
ur graphic card might not b compatible with ur motherboard.. check the compatibility list in the user manual of ur motherboard
Jan 30, 2009 | Asrock P4I45GV R5 Motherboard
I want to know of a graphics card that supports vista graphics can play fallout 3. this card needs to be for agp x8 and under $50 can you help???
Minimum requirements
  • Windows XP/Vista
  • 512MB System RAM (XP)/ 2GB System RAM (Vista)
  • 2.4 Ghz Intel Pentium 4 or equivalent processor
  • Direct X 9.0c compliant video card with 256MB RAM (NVIDIA 6600 or better/ATI X850 or better)
Jan 20, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
K7VT2 with a AMD Duron 1.30 GHz CPU.
Depends on which AMD processor you would use. If Duron you could go to 1.8Ghz. If you use Athlon XP you could go to 3200+. Athlon MP 2.1Ghz and regular Athlon 1.4Ghz.
Nov 13, 2007 | Asrock K7VT2 Motherboard
Nvidia GeForce FX 5200 Video Card Graphic Logo
73 people viewed this question
Top Nvidia Computers & Internet Experts
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
