Need to burn data DVD. After 98% complete it said : could not finish " All-in-one"" and Recording failed.
  • 304 Answers
What software are you using to burn your data DVD? And Did you try burning the project a second time with the same results? If you did not try it again as you might have had a defective disk. This can also be caused by a cyclic redundancy error with one of the files you are trying to burn to the disk. To test if this is the case, create a new folder and see if you can copy all the files you are trying to burn into that new folder. If It cannot copy all the files to the new folder it will give you a cyclic redundancy error on the particular file causing the problem. Also, Make sure non of the file names are too long. Certain copy software only support file names up to a certain length
I run into this problem myself once and a while and one of the causes above are usually one of the culprits every time. If you need more help feel free to contact me and I will walk you through all the possibilities. Also, Make sure you let me know what software you are burning with as this will give me a definite solution to your problem. I hope this is enough to fix your problem, if not you can reach me at geokohler@gmail.com and I will call you for free to help you get this fixed.
George
Posted on Jul 26, 2008
DVD burns ''successfully''...but actually burns nothing!
What comes to mind is that you are burning to an image file and not your actual burner. Make a small data DVD and name it something obvious such as aaaa. After completion of the disk, do a search for the file and see if it is in actuality on the computer. If it is stored as an image file, you need to select the recorder type to your actual burner.
Jan 28, 2010 | CyberLink DVD SUITE 6 PRO DVD
Tip
How to back up Microsoft updates to a DVD disk
<p>1. Browse to the Microsoft Download Center (see Resources). Download Exe record updates in the desired shape on a DVD for future use. Store them in a new folder on your desktop. <br /> <p><br /> <p>2. Buy or download a DVD-burning software to your computer if you do not have. These programs include Nero, Super DVD Creator, and Roxio (see Resources). <br /> <p><br /> <p>3. Start the DVD-burning application and insert a DVD-R or DVD-RW disc into your DVD drive. <br /> <p><br /> <p>4. Find the option to create a data DVD. This option can be found on the main menu of most commercial software to burn discs. In most cases this will start a wizard that guides the process of recording a CD of data, alert. <br /> <p><br /> <p>5. Select the drive drop-down box is where your blank DVD. DVD drive of your PC is recommended for most users, the "D: \ Drive Select." Next ". <br /> <p><br /> <p>6. Select the folder on your computer where the Microsoft Update. Exe. Double click this folder. Select "Edit" and "Select All" menu at the top of the window. Select "Open" to add files to the list of files. <br /> <p><br /> <p>7. Click the Save button to copy the files from the hard drive of your blank DVD. When the transfer is complete, remove the disk from the computer and the program. <br />
on Jun 22, 2011 | Computers & Internet
Dvd blank burning file problem
please uninstall software and reinstall it agai.
Jul 14, 2009 | Compaq Presario 700 470024-192 Notebook
How to finish a transfer from VHS to DVD?
When you finish recording from VHS then press Stop on dvd recorder and finalize dvd, this option would be available in dvd menu.
After finalization, that burned dvd can be playback on any dvd player.
Apr 19, 2009 | Televison & Video
HP 640b DVD Writer tray will not eject after burning DVD
If all else fails you can take it to best buy
I did that with one of my comp.
Dec 17, 2008 | HP LightScribe dvd640i (DVD640I)...
Burning a DVD picture slideshow
If you have Nero Express, try using that, as it should prepare the data for you. Also it maybe that you don't have the correct "codecs" installed. There are some Nero updates you can download from Sony:
http://sony.storagesupport.com/product/125#documents
Hope these solve your problem.
Regards,
Tim
Aug 29, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Not completing recording from HDD to DVD
DVD's are burned from the center out, so if you're seeing a small band at the center, it sounds like the laser is overheating and quitting very early in the burn process.
No idea how to fix it, maybe blow it out with canned air?
Good luck, sorry I can't help more.....
Jan 27, 2008 | Samsung DVD-HR720 DVD Recorder
Nero Smartstart slide show program
hey man!! hope i can help u
ive been researching abit and stumbled upon this
http://club.cdfreaks.com/f32/unable-prepare-data-recording-prepare-session-failed-transcoding-videos-159759/
go to it, and go to the post before last, the one with the fancy photos, see if this helps!!
hope you get a FixYa!!
Dec 22, 2007 | Computers & Internet
Burning dvd data
its telling you that the dvd are not being closed, do you wait until the computer tells you its finished before you eject the disk, most lite on dvd's will eject themselves when done.
Dec 13, 2007 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
Aug 01, 2007 | LG GSA-H22N DVD±RW Dual Layer Burner
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
